once ive bought the mhr kit should i also get a malossi crankshaft to go with it then carry on from there ?
one more thing...are malossi mhr replica exhausts good? or are there any better ones, if so name them. and would i have to keep setting the jets and carb as a new part is bought? could a dealer do this at a cost? cheers.
this is my planned set-up de-restricton... MHR REP 70kit c16, 21mm carb suit it fine. Stage6 or BGM crankSKF bearings and seals. straight inlet, Stage6 vforce reed block. stage 6 twin airfilter Transmission. Malossi or polini variator Xspecial malossi belt. Stage6 torque control clutch Stage6 wing cooler clutch bell. Visual parts, new rear indis metal footplates, stage 6 brake levers, pro taper bars, bgm stem koso digi clock conversion lexus front indis, all views welcome :good:
im going 70cc soon, my engines the same as yours. my set up will be.... stage6 sport pro cylinder stage 6 crank 21mm carb 125 inlet and reeds stage 6 pro rep exhaust and thats a nice 1st set up or you could go sports set up ? make sure you know what your doing.
yea ive got the order im going to do it and gona get it fittit by a pro mechanic. good luck with ur set up... what scooter are you doing it to? how long did you run it in for?
