Can anyone told me if the Runner's had chassis problems? Some on told me that make problem to rear suspension or to the linkage of the engine. In my Runner had a sticker "Advance Frame Technology" is a new version? Is an FXR 180 double disk.
well does it still ride ok??? generally runners have engine mount bushing problems so the engine bounces a lot? a chassis is just a lump of metal, it can only bend/rust/snap sam
I'm not too sure what they meant by the 'advanced frame techonolgy' Its basically a typhoon/NRG frame with a few extra bits welded on. The engine mounts do tend to be a problem but if they are replaced before the whole unit is ceased up, Its an easy job. (You can check if they are knackered by grabbing the engine around the clutch area and moving it, If there is play they need replaced)
