Runner bits
Discussion in 'Wanted' started by KidBilly, Jul 12, 2015.
  1. KidBilly
    KidBilly Active Member
    Zip 125
    Need an exhaust and rear wheel
  2. Stevep
    Got wheels if it's the drum model engine, still got the exhaust as well.
  3. KidBilly
    Zip 125
    I assume its disc as it has the bracket for a caliper, never seen the difference as a lot of this is new to me.
    Also not quite sure what the snapped thread/nut is(the rusty one) not got that far into it yet.
  4. KidBilly
    Zip 125
    Also will message you about exhaust, forgot about it.
  5. MARSH
    Put a picture up of the caliper mount, it look's like the original lugs have broken off and a PSN bracket has been fitted?
    KidBilly likes this.
  6. KidBilly
    Zip 125
    Yeah, its a PSN bracket for sure mate.
  7. KidBilly
    Zip 125
  8. MARSH
    Even better, drum cases converted to disc!
  9. KidBilly
    Zip 125
    Thanks for confirming will any 125/180 disc and hub fit?
  10. MARSH
    Yes, any will do!
  11. KidBilly
    Zip 125
    Should have the hub shortly if all goes well, been trying to get a rear wheel and silent block mount made up(or a cheapish frame) for a few weeks now with no luck :(
  12. MARSH
    Buy the silent block rubber bush+spacer tube, get some steel tube the same diameter as the silent bush/same width, cut tube and weld on two m8 nuts either side of the cut, use m6 nut'bolt to pinch tight on the silent bush. Using some 25mmx50mmx300mm ish long steel box section weld it to the steel tube along with a m8 steel tube for the stand bolt. Get an engine bolt through the scissor joint/silent block then offer it up to the frame, put main frame bolt through scissor joint/frame and see where it touches the main frame. You may need to cut and put a bend (downwards) in the box section then weld it to underside of the frame.
  13. KidBilly
    Zip 125
    Understand it ain't too hard just the welding I'm new to welding and don't want to put my trust into the welds holding up
  14. KidBilly
    Zip 125
    Any standard exhausts(or just downpipe)
    After one asap.
