rod bearings
Discussion in 'The Workshop' started by h.hubbyy, Aug 3, 2011.
  1. h.hubbyy
    h.hubbyy Member
    JOG R
    ohh ok. what would happen if its the bearings and i just ignore it?
  2. Jonnymarrw00t
    Piaggio Zip 05 plate
    Most likely bye bye piston/bore/crank lol.
  3. stkflote
    stkflote Member
    zip 2t cat
    if big end is gone you will be able to lift conrod up and down, side ways is normal movement,
    screw might be stuck in fly wheels or even in piston,i would definitely take off barrel and check piston it might be a ring
  4. stkflote
    stkflote Member
    zip 2t cat
  5. h.hubbyy
    h.hubbyy Member
    JOG R
    cant lift it up and down. where is the flywheel? ive taken the bore off and checked around the crank and cant see the other half of the screw. thanks
  6. Jonnymarrw00t
    How on earth would it get in the fly wheel :confused: Get a small but powerfull magnet and see if you can get anything to come out.
  7. h.hubbyy
    h.hubbyy Member
    JOG R
    so ill open it up , get a magnet in there and see what happends. what should i do to check if the bearings have gone while ive got it open? and what other things should i look 4 while it open? thanks :) and should i upjet it?
  8. h.hubbyy
    h.hubbyy Member
    JOG R
  9. Jonnymarrw00t
    What split the crank cases ? If so replace the bairings anyway don't put old ones back in. And check the crank for any obvious problems. it shouldn't move up and down but side to side movement is fine. And i'm not sure on the jetting.
