removing the barstewarding clucth from aerox
Discussion in 'The Workshop' started by Aerox-lad, Feb 20, 2008.
  1. Aerox-lad
    Aerox-lad New Member
    yeah good one mate
    HATER LOL!!
  2. LIVELY16
    LIVELY16 New Member
    LOOL im playin mate dw
  3. J-Nitro
    J-Nitro Active Member
    a bit od advice about buying the clutch tool
    buy a 38mm socket/clutch tool for the mineralli
    not the some of the biggest scooter shops stock (42mm like I bought)
  4. Dec
    Dec Active Member
    nothing ugm
    josh i bought a 42mm and it was too small for my standard clutch bell
  5. J-Nitro
    you cant have dec unless youve got a clutch nut too big than usual from somewhere?
    i bought a 42mm and that was too big
    on scooter attack it says aswell
  6. Dec
    Dec Active Member
    nothing ugm
    well the stupid numptys must have sent me the wrong size but im 100% pos i ordered biggest 1
  7. Aerox-lad
    dec change ur pic lol!
  8. Dec
    Dec Active Member
    nothing ugm
    no way i love my avatar lol im too disgusted with my aerox to broadcast it on a forum
  9. Aerox-lad
    hand us the keys if u dont like it lol! ill be having that zx off it lol.
  10. lukeyboixrace
    lukeyboixrace Member
    just make your own tool.
    buy a strip of metal cut it so theres one larger strip and one smaller
    drill some holes and attatch the smaller one about half way up the longer strip on a bolt, so its not too tight and you can swing it....make sure the 2 tops of the strips are similar levels.
    drill a hole in the end of each strip and place a nut and bolt in them and tighten them up...these should then fit nicely into two holes on your clutch bell. and when it does jsut tighten up the middle nut and bolt so it holds it securely and the bottom of the large strip will swing round and wont be able to go further then the ground (obviously) so will stop the bell from turning.
    then jsut gt your socket on the nut and crack it off. simple.
    but its much easier to buy an impact gun...even the electric 12v car cigarette lighter 1's work fine ;)
    luke
  11. Dec
    Dec Active Member
    nothing ugm
    yup its urs
  12. Aerox-lad
    REALLY DEC? LOL
