Re: Ratty to Minty/125 to 172 Update 26/08 Thanks for the tips guy on wot 2 go for, really duno wot im gonna do, im gonna ave a gd fink bout it and decided wen i get bk from Holiday as i go on Monday. Here's a lil update for u b4 i go away, as i said i got the wheels from Connor, Got the rear wheel on and took a quick pick of it. As u can see from the pic thres scratches on the Wheel and as it been Powdercoated already, it cant b dont again so it puts that of the question. Theres deeper chips that u cant see in the pic aswell
Re: Ratty to Minty/125 to 172 Update 25/09 Thats wot the guy from the Powder-Coating company said, if they been done b4 they cant b one again coz the powder wont stick 2 the wheel. So im gonna get the blue wheels done instead and have the white 1's stripped and painted
Re: Ratty to Minty/125 to 172 Update 25/09 he's talking out his bum.... you shot blast the old stuff off then re powder coat them in what ever colour you want, how do they think people change what colour there wheels are .... dulux and a brush? try a different shop james mate, ps what colour you want to do?
Re: Ratty to Minty/125 to 172 Update 25/09 Im goin for white on the wheels, that woz the idea wiv the so called MINT wheels i brought from Connor
Re: Ratty to Minty/125 to 172 Update 25/09 Yeah what fireman sam said, I nitromorsed my wheels before I sent them for powdercoat.
Re: Ratty to Minty/125 to 172 Update 25/09 lol if it wasn't what he said it was you shouldn't have taken it pal, theres pleny mint ones out there, i think me and t3rr0s have some in our pile, but you've got it now so :doh: .... where about's you located? so you definitely going with the white and red colours?
Re: Ratty to Minty/125 to 172 Update 25/09 james man! sell those blue ones on ebay to cut your losses and get the white ones sandblasted and powdercoated. the money you get from the blue ones should cover the sand blasting at least? OR try and touch up the white ones? depending on how bad they are(dont look too bad from pics?) i know its bodge but you gotta make the best of a bad situation right? it might not look half bad once touched up. youll only be kicking yourself the first time you dink your brand new powdercoated wheels. for touching those wheels up use a bit of white hammerite and a little tiny paintbrush. ive done white wheels before with white hammerite it looked good. ive got white hammerite here if you wanted to try when you get back or somthing?
Re: Ratty to Minty/125 to 172 Update 25/09 Taking the tyres off £5 max. Sandblast and powder coat £50. New front wheel bearings and fitting £15ish. Even if you do strip the paint off them before taking them to be powder coated they are still going to sandblast them anyway. They do it to remove contaminants and so its rough enough that the powder will stick properly. Those wheels are deffo fucked. A long way past being able to touch it up.
Re: Ratty to Minty/125 to 172 Update 25/09 why are you cryiing? i come half way with the stuff all you had to do was take a sec look at them and said if you wanted them or not no skin off my nose, you took them your fault thats how i got them couldnt be botherd to wipe them down so i told you they needed it yousaid ok thats fine. if you had said no you do it i would have then told you the con.
Re: Ratty to Minty/125 to 172 Update 19/10 Update 19/10 Just Had Sum Goodies tune up at my door this morning, just need 2 order the Crank Bearings and then everythin is ready for Minor 2 cum pick up on Sunday :grin: 54mm PM-Tuning Crank Water Pump, Gasket Set, Vari Nuts and a Relay
Re: Ratty to Minty/125 to 172 Update 25/09 a xbox controlled runner hock: that's going to be sick :good:
Re: Ratty to Minty/125 to 172 Update 25/09 I knew sum1 woz goin 2 comment about the xbox controller lol Its gonna b used for the renthal switches lol
Re: Ratty to Minty/125 to 172 Update 25/09 Ive started to fit my water pump and ive got it in the same position as Shiny has in the pic All i need 2 do is wire it up 2 the loom so it turns on at the same time as everythin else, can sum 1 help, i cant get hold of shiny atm lol
Re: Ratty to Minty/125 to 172 Update 25/09 Finally got the Water Pump workin, Well i fink its workin lol, I know that if its workin properly then there shud be coolent cummin bk 2 the coolents bottle but shud the b loads cummin bk or wud that b becoz of the pump i have.
Re: Ratty to Minty/125 to 172 Update 25/09 coming along sik this one bruv ratty to minty for real :good:
Re: Ratty to Minty/125 to 172 Update 25/09 Yup goin well, Engine will b sorted in the cumming weeks, wen thas bk in the bike i will concerntrate on gettin it look how i want it
Re: Ratty to Minty/125 to 172 Update 25/09 comming along nicely mate!! when you put the ellecy pump in did you block off the old mechanical one in the engine or are you just running both???
Re: Ratty to Minty/125 to 172 Update 25/09 The water pump in the engine dont work, thats the reason for the Electric Pump
Re: Ratty to Minty/125 to 172 Update 25/09 Here is my bike in the garage atm And Here's my Engine waitin for Minor to pick Her up :grin:
