That's a good bit of info for people looking at running pre mix. I wasn't even sure what ratio I was running, just used the little jug I was given when I had the bike properly set up. It says 5% on the top of the jug, so that's 20/1 then. Is it necessary to run that ratio? I hear others saying the do 33/1 or more.
How do u know what ratio to run. 70 kit, sports pipe (pm360). Like wht Are the standard ratios for street tuned 70s
i run 50:1 and found it to be twice what the pump throws in there (avaraging fuel vs oil litre per mile) never needed to run so much oil..
What ratio should i run my gilera ice i have just rebuilt it with 70 kit racing variator racing clutch de restricted cdi de restricted manifold 21mm carb racing exhaust ect
just remember that when you mix in the tank so try and know how many gallons to fill and pour on oil first, otherwise it can be difficult and mix oil and gasoline that can be a problem that many do not realize
