Piaggio zip sp 70cc really hard to get started HELP PLEASE
Discussion in 'The Workshop' started by LewisDibz, Aug 24, 2013.
  1. LewisDibz
    LewisDibz Member
    Piaggio zip 70cc
    Hello all hop you are all ok :)
    I have a piaggio zip sp 70cc it is really hard to get started like it will take about 20 kicks sometimes double that to get it fired up also have to have the throttle fully open. But when started it will run great with no problems at all but then when the bike is turned off it will take even logger to start sometimes it want unless you leave it for about 30mims but then it will start again after about 20 kicks off the kick start sometimes it will start on the electric start but its will flatten the battery.
    I have cleaned the carb out
    Checked the reed vavle that's fine
    Replaced the spark plug
    Drive belt is fine
    Parts that's are fitted are
    PM TUNING 70 KIT
    17.5 CARB WITH 80 MAIN JET WITH STANDARD AIR BOX
    STAGE 6 EXHAUST
    3.5G ROLLERS
    POLINI CRANK
    ANY HELP WOULD BE GREAT GUYS AS STARTING TO DO MY HEADING NOW
    CHEERS :)
  2. Stevep
    Probably need to up the pilot jet size. Not the main. Buy the pilot jet pack. 10 jets in it.
    Need to know your size first then go up from there.
  3. LewisDibz
    LewisDibz Member
    Piaggio zip 70cc
    is that the small one next to the main jet mate???
  4. Stevep
    that'll be it
  5. Stevep
  6. LewisDibz
    LewisDibz Member
    Piaggio zip 70cc
    ok nice one mate i have been looking all day there is a few poeple on here with zip that have the same problem as me lol when its started it runs great but its really really hard to get started up sometime want really want to get it sorted haha
  7. Scooter-Noob
    Scooter-Noob God among idiots
    AEROX in box's :-D
    could be a choke problem. get a manual one, auto chokes are just a pain
  8. LewisDibz
    LewisDibz Member
    Piaggio zip 70cc
    Yer was think that am gunna put my mates on off a runner and see if its that lol
    I did disconnect the auto choke but still no look getting it started
  9. Scooter-Noob
    AEROX in box's :-D
    disconnecting the choke would not fix a fuked choke?
  10. LewisDibz
    LewisDibz Member
    Piaggio zip 70cc
    Ok mate ill try my mates tomoz and ill keep you posted on how it goss hopefully it works
  11. Scooter-Noob
    AEROX in box's :-D
    yep as it coming from a working bike you know it's working,
  12. LewisDibz
    LewisDibz Member
    Piaggio zip 70cc
    Yer that's what I was thinking lol gunna just use his carb the full lot and if its that am gunna buy a new carb
  13. Scooter-Noob
    AEROX in box's :-D
    will it be set right for your bike
  14. LewisDibz
    LewisDibz Member
    Piaggio zip 70cc
    Not really just gunna put my jet into it, i just wanna see if it starts if it dose then I know my carb/choke has had it want be riding it or owt
  15. Stevep
    Wont work right. Putting your jet into his carb wont change a thing. He may well have a different size pilot jet as well to yours. Try just changing the chokes over instead, they should be the same.
  16. Scooter-Noob
    AEROX in box's :-D
    well it will work. 99% of after market bikes dont have any carb set up other that a main jet change and 75% of them work fine
  17. LewisDibz
    LewisDibz Member
    Piaggio zip 70cc
    Well ill let you know How I get on guys with swapping carbs :)
