What is the simplest way of converting a zip 50 wiring loom to run a 125 skipper engine i have 125 regulator cdi and coil, but dont know how to wire it into the 50 loom. Some take me through it step by step ??
125 loom off what ???? A 125 zip is 4 stroke and if i took it off a typh or sumat then i want my clocks and shit to work aswell which would be hard to do all the plugs are different...
u can use a 125 loom from skipper or typhoon you would also need the regulator from the 125 to control turning bike on and off use the small green wire coming out the stator harness connect that to the harness from ur 50 zip where ur original cdi once was there will also be a green wire there ur gauage works from the battery so ones there is a battery you gauge will work to charge you battery you will use the same wire that was present to charge the 125 should have battery terminal on it still for light the 50 regulator cant handle the amp so i would have to take out put wire witch would nomaly feed ur head lights cut it and join it to the light wire from the 125
