Piaggio Typhoon 125 2t Malossi variator
Discussion in 'General Scooter Discussion' started by oscustomsuk, Mar 19, 2021.
new crank
  1. 1
    0 vote(s)
    0.0%
  2. 2
    0 vote(s)
    0.0%
  1. oscustomsuk
    oscustomsuk New Member
    Hello everyone .need some help please
    I have a Piaggio Typhoon 125 2t engine I tried to put a new Malossi variator on but it would not fit because the crank threds have worn down .
    is there anyway to fix this or will I have to get a new crank .
    thanks
  2. MARSH
    There's nothing wrong with the crank, there all like that on 125/180cc Piaggio engines, just fit the variator with the supplied spacer. A well set up std variator will work just as well !
  3. oscustomsuk
    thanks
    Don’t seem to fit even with the spacer variator just spins .
    I had to add 2 shims to make it lock in place but now there's not enough space to get the other parts / nut back on .
    I might have to get a stranded variator again
  4. MARSH
    That's the problem with Malossi variator, yes it spins, it is designed for a race crank that has splines all along tail of crank, the std variator will work fine on std crank. You can't shim it to fit.
  5. oscustomsuk
    ok Thanks again .I have ordered a standard variator .
    talk soon
