Piaggio engine rebuild
Discussion in 'Maxiscooter Tuning' started by GazD, Sep 22, 2013.
  1. GazD
    GazD Active Member
    interested in fitting an aircooled engine to my italjet dragster,,they come with the gilera runner liquidcooled engine
    any ideas?
  2. Stevep
    Yikes, thats a lot to think about.
    Why not just get a water cooled runner 125 lump, loom and cdi, and then mod that to a 180?
  3. MARSH
    You need a rolling nut typhoon 125/Aprilia sr 125 rolling nut engine (with caliper lugs), these are the same cases as a L/C runner with out the water ways, these engines are drum brake as std but can be converted to disc and 13" rear wheel very easily. A 172 barrel, full circle crank, 25mm carb and a decsent pipe will work fine. As for the ignition I'd stick with the std a/c system, people say to use the L/C set up but mmm, I'll stick with what's made to fit n work!
