Peugeot cdi bypass
Discussion in 'The Workshop' started by rems, Jun 23, 2014.
  1. Merlin
    Merlin Old School Biker
    2007 TKR WRC 50
    @ Rems
    I posted this on Scooter Nations - it's for the Speedfight 2 but it should translate to the Vivacity.
    http://www.scooternations.com/showthread.php?9372-Speedfight-2-100cc-ignition-repair
    This wiring scheme should work with a bypass CDI unit. Try a quick hotwire as per the 'ignition on' and see if you get a spark. You should with a bypass CDI, as long as you have the correct black wire and not the lighting wire.
    @ Mark,
    Can you please confirm that on the Speedy 1/2 where the wires are oriented in the plug that goes into the back of the ignition barrel?
  2. rems
    rems 2000 pac man zip
    I wired up the old CDI from the pictures and I found that the coil was dodgy so fit old one and work :)
    But now have a cutting out issue on full throttle but I put this down to no weight on the bike
  3. Mark Emerson Trentham
    Basic,ACI,AEC.? mk.
  4. Mark Emerson Trentham
    S/F,basic.from left:-black,green,black+white,red,red+black.
    S/F,AEC 400,from left:-
    black,green,black,red,red+black.
    S/F,ACI 100,from left:-
    black,red.
    All factory 'spec.,no cut/shut.mk.
  5. rems
    It was ACI100 but a bypass unit so I'm happy as got the whole donor bike for £30 lol
  6. Mark Emerson Trentham
    I hate you now..............:D.
  7. Mark Emerson Trentham
    Bypass units (new),run 'bout £50.00,gtrrrrrr.
  8. rems
    Yea I know haha but now have running issue at full throttle but need to test ride it to find out loo
  9. Liamm6
    Liamm6 New Member
    Hi can anyone help me will a speedfighter 100cc cdi fit a vivacity 100cc?
  10. Pedalbikes
    Pedalbikes New Member
    Got speedfight 100, 1997 model. Iv got no spark and I think the immobilser is cocking about but i DONT want to spend £100+ on the AEC400 bypass unit, got any suggestions?
  11. dan189216
    dan189216 Member
    would this be good spec set up for piaggio zip ac?
    - Stage6 chrome exhaust
    - Stage6 21mm R/T MK II PWK racing carb
    - Stage6 SportPro 70cc aluminium cylinder kit
    - Stage6 19x15.5 variator roller box set (6.5g to 9.5g)
    - Stage6 drive belt
    - Naraku HPC racing full circle crankshaft
    - SKF crank bearings / seals C4 - uprated race
