when i open it up it dies in power and i let off to get the power to build up again at the bottom of this thread there a post by the member whooot that has a similar set up and says 79 jet http://www.scootertuning.de/faq-bes...r/373368-faq-diverse-set-up-s-abstimmung.html
then try it with the lighter rollers. the 8.5g are 100% too big so don't use them again you problem now will be jetting, your rollers may need fine tuning but get the jetting right first
yer 40mph is not an unreal speed to expect just remember if it runs on the 100 jet it may still not be spot on so dont spend all day hammering the bike
i have just seen that a piaggio 50cc with the 17.5 when derestricted will be using a 65 jet, so i think your jet as to be too big. even with a free flow filter it would not go 65 to 100. and now you say the plug is black with normally means its rich. i think your best bet will to be buy a jet pack around size 75-95 start big and work down http://www.pedparts.co.uk/product/1085/motoforce-racing-dellorto-6mm-jets-box-jetbox or save a few ££'s as you already have some just and just buy in a few steps you have 80, 100? buy a 70 and 90
i found a 56 jet in my wallet lol my other option is i have a 14mm dellorto carb in my garage might be better to use as standard is 12mm with 72 jet
if you go to the stock carb you would have to add jets for the exhaust and air filter so ever way you neeed to rejet, and the 17.5 will give you more power
the original vivacity carb setting is this Carb Type Gurtner PA370 Pilot screw initial setting 1? turns out from fully screwed in Float height not adjustable Idle speed 1500 rpm starter jet 45 Pilot jet 42 Main jet 72 Needle clip position L3035H at top notch had an issue with the 17.5mm snapped the the brass tube thats sticks down in the float chamber
