Hi guys, Yamaha ovetto 100cc 03 I hope someone can help me with this issue, I have just bought a non runner due to it not having a ignition barrel and so on , However I can buy a replacement but dont know where it would plug in as I cant see the connection where it would need to go, I have looked online and YouTube but no one has released a video which is shocking, I have maybe one image of the front panel but cannot find anywhere to plug a new ignition in and so far there is two types so need to know which one, if anyone has any info please let me know Cheers in advance
Have you got any images or anything like that to show where it would connect ? , just looked online cant find anything, looked at the front end if the bike cant see anywhere where it would connect into it's weird
Ok thank you I will check out tomo morning and see if I can see one , hopefully I can and then that solves new key issues Haha Cheers bud
Have you got 3 or 4 loose wires going to nowhere? Looks like someone may have either moved them or cut them off????
I have 3 loose wires two are tied together ? With a red plug 4 pin so I'm assuming this is where it needs to be replaced ?
The ones with nothing connected are red white and brown ? That's the only ones I can see , theres just a bulb hanging down next to some other stuff which is the headlight so I know its not connected to that
I cant really read it, do you have a link for that image ? , I believe it will be these 3 wires not connected to anything , from where I'm looking at ignition barrels online but matches up I believe, got this bike for £50 and needs little TLC eg front panel headlight oil pump and ignition , then it will be riding around
Looking on your phone? You should be able to download the complete service manual pdf online, I can't upload this type of file here
Yeah on my phone , I think the red block 4 pin is where I need to fit it , so I'll order one and fit it , there is no videos on YouTube for this its mad
I believe they might have , got a little bit to sort out but just couldn't see where to plug a new ignition in , but I'm going to strip the handle bars down make it look bit sporty Haha, cost me £50 as project
