okay, not got a clue.
Discussion in 'The Workshop' started by jtkm47, Dec 4, 2007.
  1. jtkm47
    jtkm47 New Member
    like what? its not releasing ?
    my dad said it could be clutch but i think diff :p
  2. capri dave
    capri dave Active Member
    if the chokes stuck on...it will run really rich when hot!!
    so maybe when you stop and let it idle the plug is fouling up causing rough running!!
    could also explain why it runs ok when cold...as the engine needs a richer mixture when cold!!
  3. jtkm47
    jtkm47 New Member
    not choke, its manual and ive checked it all and it alll releases fine.
    had a fiddle with carb mix, a bit better, but only goes 40-45 but it used to go 55-60 clock speed.
    so
    basically
    WTF!
  4. jtkm47
    jtkm47 New Member
    RIGHT!
    no air leeks, pipes fine, carbs fine, throttle and choke are fine.
    it feels like its restricted or somthing, it revvs fine on the stand, but it doesnt on the road, i havnt get a clue and now its really funking pi55ing me off!
  5. MiNoR cOnFuSiOn
    ok, have you xchanged any parts recently?
  6. jtkm47
    jtkm47 New Member
    nope.
    i took the carb off on monday to check the jet size, and put it all together identical to how it was, then the problems began.
    since then ive cleaned all the carb, breathers, cables etc, sealed the exhaust and manifold, changed rollers but still problems!
    could i have had a partial seize?
  7. jtkm47
    jtkm47 New Member
    also, could the spark plug be effecting it ?
  8. jtkm47
    jtkm47 New Member
    oh yeah, my dad seems to think its the clutch, or somthing to do with transmission, although i disagree
    the engine does rev okay on the stand, so could it be nything to do with the clutch, i thought it would revv a lot with a dodgy clutch/belt but not move as mch as it would slip?
    any ideas, 'cause im running out of ideas!
  9. capri dave
    yep always worth putting a new plug in ;)
  10. jtkm47
    jtkm47 New Member
    yeah, i just find it very stange, how its working fine, i take the carb off, dont alter anything, put it back as it was, and its crap, and ive also checked like everything else and still shit!!!!
  11. capri dave
    its gotta be something to do with the carb then!! maybe youve disturbed something or not put something back right!!!
  12. jtkm47
    jtkm47 New Member
    its back how it came off, its all been cleaned etc.
    then again it was fine in the next morning after taking it off, and half way home in the afternoon, so somthing else could have gone in the process, i was ragging it home a bit locking up etc
  13. capri dave
    locking up!!! :w00t:
  14. jtkm47
    jtkm47 New Member
    yeah... ? so ?
  15. harrisp
    harrisp New Member
    Try a new spark plug, they can cause a lot of problems.
    Where abouts are you? Someone might live near you and may be able to help you.
  16. jtkm47
    jtkm47 New Member
    its just really weird any annoying!
    used to be good, and nippy, now its just flat and shite!
    gets to 40, it feels like it wants to go more...but...doesnt! even when you get downhill now it doesnt really wana go
  17. jtkm47
    jtkm47 New Member
    right, im goig to get a new plug in a bit, it looks fine, but just to be sure.
    it was ok for half the way home again then went rubbish lol.
    ive tried tweaking the carb, but i dont want to go 2 lean n seize
  18. jtkm47
    jtkm47 New Member
    it hasnt been as bad today.
    new plugs fitted.
    it has been a bit better, i think carb settings
    could the diaphram stick in the oil pump ?
  19. jtkm47
    jtkm47 New Member
    pretty much sorted now.
    thanks to peoples advice, although i expected a bit more from all these scooter enthusiasts!
  20. MiNoR cOnFuSiOn
    well, its hard with the description you gave us. id say sticky float.. but if your a bit more specific next time we can help more..
