The MHR Rep reedblock is the same as a standard reedblock anyway. Well pretty much. Go for an EVO if you want to upgrade. I'd go with the Top Perf cdi as well but it's only needed if you do upgrade to a better kit. Annd as for the variator's the Malossi one you have got looks like the normal Multivar. You should use the Polini if you are fitting the Polini torque drive. You should always match your transmission.
thats what i thort about the vari terro just wondering which was better i will use the top performances cdi as i might be upgradeing to mhr rep bore and i will save and get a evo reed block as well how much are they and are they better than a mhr reedblock
hm this NRG project has been going on for years like my old bike i was in the verge of burning it but then someone handed me £300 and even then i wanted to burn it.......... GOOD LUCK those rims look sexy as fuck but u aint the first :w00t:
making it look good bruv well done still cant believe i didnt no about the secondary gear up :msn1: lol
ignition curve on the top performance cdi is identical to stock without a limiter so the athena is slightly better. the variator is a multivar 2000 so the polini is ALOT better (gives you more top end) also if you have both gearups an iron kit wont really give you the power to push the speeds.. im guessing thats why your old bike was a bit of a slouch off the line stevo
Minor would that CDI fit my bike and be ok for me just to run in etc? and then ill buy the full polini ignition. if it does then do you wanna sell one nrgandy? james
ether would work m8 as there unlimited. the timing wont be too far out but it wont rev as high as it should as there isnt enuff timing advance past 12k better than being stuck at 10k tho
yes i will sell the top performances one and minor im geting a mhr rep bore and evo reedblock and when i have some cash spare i will buy a c16 so will it make more use of the gear ups. and the malossi vari is being sold soon and im useing the polini vari
you got it in 1, lol. i should of looked really :msn1: and it also explains when going in a straight line for about a mile the stupid nrg clocks where reading about 90mph n know1 would believe me stupid bike lol
right shes running but not good so gonna get it set up soon pics will be up either 2moz or saturday or sunday depends if i get these forks im after
panels are nearly finished need few more coats of laquer but soon i plan to take the bike to be setup its just geting it to the shop as i work weekends and my dad works thru the week i may end up staping it into are car to take it up
ye ill have to see whe the swf meet in notts is then we can decide to meet somewhere after that unless u wanna go to notts
