NRG 50 wheels on Typhoon 125
Discussion in 'Visual Modifications' started by CBX, Mar 29, 2023.
  1. CBX
    CBX New Member
    Hi guys, I'm new, I need some information. As the title suggests, can the rims of the NRG 50 (2005-2009 model, with disc brakes) be mounted on the engine block of the Typhoon 125 (2 stroke, 90s model, I don't remember the year, with drum brake)? For the disc brake there is no problem, it is not a street-legal scooter so I will build a plate to mount the caliper. I just need to know if the rear rim fits on the block. Thanks for the info guys!
  2. MARSH
    Depending on year or if an engine replacement what size rear drum ? If it's a small drum them a NRG Mc3 wheel will fit straight on, as for the front a NRG Mc2 wheel will go straight in with speedo drive, all that's needed is the caliper spacing with 2 nuts ! I did a post on visual mods section I think a few years back, have a look.
  3. CBX
    CBX New Member
    Thank you Marsh, now I'm not at home so I can't measure the drum, maybe this weekend. I'll look up your post, and as soon as I know the diameter I'll let you know
