nrg 125
Discussion in 'The Workshop' started by scottnrg, Oct 11, 2008.
  1. scottnrg
    scottnrg New Member
    i got a standard carb 20.5 dellorto an nrg 50 tank an how can i check if the petrol cap thing is ok cause when i take the petrol tube of the carb petrol poors out so im guessing its ok
  2. 2stroke-power
    2stroke-power Active Member
    on 1-wheel
    it shodent piss out ,it shouldcome out wen u suck on the vacuim tube, try changing the petrol tank worth a try
  3. scottnrg
    scottnrg New Member
    try changing the petrol tank to what one cause no other petrol tank would fit
  4. RY4N172
    RY4N172 New Member
    i got a spare tap here i dont need.
  5. scottnrg
    scottnrg New Member
    will it fit onto a nrg 50 petrol tank cheers
  6. 2stroke-power
    on 1-wheel
    most taps are the same any piaagio 1 shold do and imnot sayin %100 that it is that . and check your choke wires are pluged in probrly
  7. scottnrg
    scottnrg New Member
    ok yh choke is all pluged in but how can i check that it is working cheers
  8. RY4N172
    RY4N172 New Member
    dno mate i got it given to me dno what bike it was off.
  9. MiNoR cOnFuSiOn
    long filter tap fits.. the runners are shorter and smaller diameter
    take the choke out the carb, turn the bike on then off.. the choke should move
  10. scottnrg
    scottnrg New Member
    cheers for the help i will try that tomorow an let you no cheers
  11. nrgandy
    nrgandy New Member
    i had same kind of problem as you this turned out to be the fuel tap i opted to use a gravity fed tap i used a oil tank tap and it works perfectly
  12. 2stroke-power
    on 1-wheel
    yer wen i chaged mine it fixed it aswell
  13. MiNoR cOnFuSiOn
    so ye, your 3 pages of "help me help me help me" in the most impatient manner resulted in everyone telling you what i told you in the first place... get a haynes manual befor you start mesing wiht things you dont know about.
    oh and fix all the shitty bodges on your bike (im sure its coverd in them, its an nrg 125 wc ffs)
  14. scottnrg
    scottnrg New Member
    cheers for the help everyone an minor i havent bodged my bike i have took my time doing it cheers
  15. 2stroke-power
    on 1-wheel
    u got it running
