nitrous oxide system
Discussion in 'Maxiscooter Tuning' started by alexsr70, May 30, 2008.
  1. MiNoR cOnFuSiOn
    leave your jeting as is.. ask a specialist what jet for what fuel and no2 as its pasive jetting (the same for everything, just a caser of extra fuel to no2 mix)
    there should be a prime switch (a switch to turn the lot on ie both solanoids and fuel pump) then the trigger switch.. you can use a double throw down to switch the horn/starter button over to a diff curcit so you have 2 switches (one to turn it on and one to switch the button of choice) then you press the horn/starter and its the trigger for the sys... jus hold on tight and for fuck sake dont use it under 40mph LOL
  2. kyle1b1
    full power+nos start off ftw !
  3. MiNoR cOnFuSiOn
    obviously your bike is slow as i cant full throttle a 172 off the line without laying over the bars... like, literally :D LET ALONE with a bit of funny stuff
  4. kyle1b1
    i cant either.
    but i thougt it would be rather funny to watch :bird:
  5. nrgandy
    nrgandy New Member
    giveme the kit and ill show you how to flip a bike lool anyways looks good get a vid if you do fit it it would be quite interesting to watch
  6. baz172
    baz172 Member
  7. alex_1966
    alex_1966 New Member
    wheelie double backflip lol :rofl:
  8. J-Nitro
    J-Nitro Active Member
    all of the above setup
    an RED MALOSSI clutch springs with the nitrous being used
    nice knowing you max ;)
    :w00t:
  9. MiNoR cOnFuSiOn
    if its been setup just whip out the jets and go up an even number (so justadd 2 or 4 or 9 to each jet size and it will be the perfect mix) not a percentage gain/mix like with fuel/air.. its predetermend gas and no2 so not like a carb where the incomming air pulls the fuel out. the solanoids literally spit whatevfer mix you tell it to and the mix is determend by the offset of the jet size.. so the same offset in number form counts with any size.. get it?
  10. Martin
    Martin New Member
  11. MiNoR cOnFuSiOn
    good link... the guy seriously does know his jap's an gas.... :D his tutorial on dyno's is superb
  12. kyle1b1
    yeah you read what happened to his bike right at the bottom ?
    :rofl:
  13. WOLFFY
    WOLFFY New Member
    Nitrous kit blow it did it? :p
    Haha.
    How come you need them?
