nope been at pirbright and kids being off any ideas about had to get my laptop fixed first cant remember login
hi chewy.if you've got petrol coming out of your tank,your half way there....if you get an inline petrol tap to turn it on and off ..gives you the option of relying on the float or not..just plug up all the outlets on the 4 way tap that you don't need and then strip your carb and check the float is the right hight..thats the bit that sounds like its not shutting off and causing petrol to piss out.old carbs and petrol standing for a while get a bit gummed up and the dinky pin that stop the flow when the bowl is full gets a bit mankey.if it starts its a bonus...so long as no one with half a brain has mucked about with it it will likely just need a clean up.pen and paper and take every thing off,write down all the positions of screws and stuff and take pics if you ain't sure what's what..theres bugger all in them really to worry about...so long as you don't bend or force anything you should be fine.clean all the holes and don't use force..once its together ...turn it up side down and gently blow down the petrol inlet pipe..if you feel a slight pressure..its probably a goer..if it pisses petrol...float arm needs bending or the pin ain't seating right cos it might have a naused seat seal. one thing at a time take it steady..welcome to the forum...
hi chewy..just noticed you been posting for a while...should be less impulsive and more observant...oh well...hi anyways...
did i done yer head in mark??? I shoud have made my post less ambiguous.meant I should look at the posters prior message count before welcoming them as a new member...thought chewy was a newby...impulsive again(me)hows yer frame going?.
Yup.!..,thought....hang about a min.,your man was last on Sept.13? till yesterday.. - ........absolutely fekking dyyyyiiiinng to get my mitts,on those wire brushes,uhhh huh..
got a few dinkey ones for a drill but cant beat a big one and an angle grinder...wish I was there with ya.saves a fortune on paint stripper too.
Have'nt used or will be using paint stripper,too late anyhow,as done most BEFORE.!.,i'd even thought along those lines....will say one thing guarenteed,for sure - I WILL BE B....X.D,if i'm doing it like this again (sandpaper,LOTS.......of it) - took a while before it truly sunk in ..........smegging ancient diamond hard Honda laquer,grrrrrrrrrr.
