right, our lads vx 125 is now sorted as you may know it runs perfect and starts on the button [ most of the time ] but now ; when the starter engages there is a cling cling cling noise ,like something is loose if it were a car I would say that it was the ring gear ive changed the bendix gear and checked the starter motor. I don't think it is the solenoid but im probably wrong even with a fully charged battery this noise is apparent now its made this noise from the day he got it 3 weeks approx. but today after hearing the noise and choosing to ignore it again the starter didn't want to engage and just whizzed , [ which points to the solenoid ] but eventually it finally engaged and cracked up straight away once its running its as quiet as a mouse and rides spot on hopefully its not a split engine job [ wishful thinking I know ] so can any of you guys come to the rescue please Im alright with spanners and the like but I need to know whats wrong before I can fix it cheers guys
Hello Nell.ide have a look at the teeth on the bit the bendix engages onto ..if your getting a wizzing noise but no engine turning over,chances are its a bit worn...try kicking it over and then use the starter.if the starter turns the lump more often than not doing that.chances are its what you think it is..Teeth would then be in a diferent place and engage but when it gets to the bit thats worn it wont turn and your back to square one. I hope it ain't gonna be like the last issue...have a check that there ain't any washers to pack out the Bendix..might noot be throwing out far enough to engage
ay up jim I did have a quick look at the teeth when I replaced the bendix gear they all looked fine. but no kick start on this one im afraid bit confused now tho when you say "chances are its what you think it is" solenoid? ring gear ? where is the ring gear? inside the cases on the end of the crank? its a sort of chinging sound , quite loud , rather like an old bicycle bell falling down some concrete steps talk about confused.com
Oh dear.right.I'm not familiar with the engine ...just going by what I've experienced in the past with "conventional" engines..if the Bendix goes inside the engine out of sight..that's where your engagement for it will be.is the battery a new one..mine didn't start at all well with an old battery.though it held a charge and sorted the lights well ....it didn't like cranking the engine fast enough for it to catch..if you've got a good charger that can supply a hefty current or a car with some jump leads..try a jump..the jangly noise I can only stab in the dark at..sounds like something's loose..at a guess...but knowing the last problems solution...could be anything.
no its not a new battery but it seems to hold its charge enough , I have to keep charging it tho cuz our lad keeps starting it every farts end but its not being ridden to charge it back up hes got his cbt on sunday then he,ll be all over the place on it and hopefully the battery will be constantly charged ive just been out to it this morning , its bloody cold today, its been on charge all night and it started straight away ,turning over really fast with only a hint of the changing noise so It could well be the battery after all we,ll see how it is next week when its I constant use
Might be a good idea to get a new battery and have one on charge and ready for the next weeks CBT if it plays up.I can get about 10 minutes of cranking time on mine before it starts to slow abit..has been a bit cold here too and a kick is better for mine to start on than the starter lately.doing 10_6 nights and mornings a bugger to start it with the damp too.feel like a vampire...its time for my coffin so I'm off to sleep...
tried it earlier and it wouldn't have it, it was turning over ok but not really fast so after a 30 minute charge I tried it again and it cracked up right away and it turned over a lot faster so I reckon you are right and a new battery is needed , he wont like that lol
Well,Christmas is coming and a little battery wont take up too much room under the tree..if its charging OK on a charger ...it should be OK for now but best to get a new one and you won't have the grief when he cant start it miles from help.your know if its any good after he gets the c.b.t. and rides it about for a while..I know what its like having a bike and not be able to ride it..new battery for chrimbo and hold on to the old one for emergencies..
A new battery will only be around £35, well worth the money. From new or anytime it need's charging with a low amperage charger, less than 1 amp! Car battery chargers are a bit to much for bike battery's.
thanks guys , id better get a new un then ive already thought of the "me ped wont start " scenario , don't fancy that on a frosty evening at 10pm when he finishes work new battery it is merry Christmas guys
I think ive found the problem guys looked a bit deeper today the variator back plate ,the dish with the sliders on has no teeth left on it so ive ordered the complete shibang complete variator assembly,comprising of the variator,back plate,sliders,rollers,belt,spacer luckily the splines on the crank look ok so that,ll be the changing sound when starting I assume also ive had the clutch off and gave it a good clean and blow out and roughed up the clutch plates with sandpaper too the clutch bell was full of filthy crap which needed brake cleaner to shift it the clutch plates don't seem to be contaminated so we,ll have to see what happens tell ya what guys, you soon learn how these things work [ or don't work ] don't ya? our lad should of bought a bloody frame and had me build it up bit by bit by the time weve finished give me a Honda grandad 90 any day
righty then fitted the new variator assembly ,back plate,variator,rollers,spacer,and a new belt AND ................................ it starts ,its turning over much better BUT.............. the clinging sound is still present and the starter motor seems to continue to turn for a second or 2 after the engine has started it must be the starter motor itself as ive replaced the bendix with a new un ! but at least its starting now ready for his cbt on sunday whats next ????
Keep at it, I'm also a parent on a learning curve with twist and goes, to think a month ago I didn't know what a variator was lol. You'll sort it all out and get it better than new in the end
lol yeah ive had all sorts of bikes in my time from ap50s, fizzes, rd350s,ktm950,z1000 etc etc but every one ive had has had proper gears and clutch and a proper petrol tap which you can turn off , and a reserve tank I just cant see what there is to like about these ped things little wheels,crap ride,too much plastic, anyways I think [ hope ] its sorted now until next week lol
Hi hi Nell.these things are sent to try us.if your starter is still turning after your button is released then ide say it MIGHT be a sticky solenoid relay starter unit thingy..don't now where it would be on yours but it will have the thick wire from your starter motor connected to it ...trace that wire back and...bingo..there it is...2 nuts a couple of thin wires too on it...easy swap..fix?..looks like the variator (ring gear) was worn after all..were all learning with these things..have you had a look at the clutch mechanism..if the noise is only there when your cranking it..it could be a naff starter motor..and If every things tight at the variator end...the noise may be at the clutch end..as it all takes up the slack from running it all pulls together but when it all at rest there's a bit of slack in the system...could be that its all pulling together and the slack disappears and then no noise..if yer know what I mean...
Tell me about it. I did his throttle cable, it took me 2 minutes to fit and adjust the cable but 2 days in all to take off all the plastic, replace all the missing screws and put it back together as it should be. I also had to remove the under seat toilet thing and take off the exhaust just to be able to see the oil pump and check it was set right with the new cable. I currently have a Honda VT500E, nostalgia thing from my courier days in the past, but have owned all sorts of bikes in the past, biggest being an FJ 1200. Also in recent years had a Pan European which didn't do my back much good but it was one hell of machine. My own ped back in the day was a Suzuki ZR50, I could get my head round that OK as it was just really a little motorbike with a real gearbox, chain and sprockets and stuff Still we won't let them beat us eh
lol under seat toilet lol lol yes jim the starter solenoid was my next port of call as you say everything is tight on the variator end and ive cleaned out the other end sorry clutch end lol but as it is its running at the mo thanks for the pointer regarding where to find the solenoid il have a look when I get chance but I reckon that after sunday we wont see our lad for a while sorry ,that's when hes got his cbt il keep you all posted thanks guys btw why don't his helmet fit in the under seat toilet?????lol
Beats me, we found this out arriving at footy last week, first time he used it to go somewhere rather than just riding around. Takes off helmet, puts it in toilet, seat wont' shut. Turns helmet around still won't shut. I thought that was what it was for. Still it is a good place for a hefty bike lock. He didn't half moan though about having to carry his helmet. So I decided to get him a small top box for xmas, cheep on Ebay and will just about take a full face helmet.
hmmm I tried my helmet in the "toilet" today and it fits now mine is a large and his is a small I think that the hump in the middle of the "toilet" is too big for a small helmet if that makes sense lol so im gonna remove the hump ,[theres only 1 screw holding it in] , and see if his fits,if it does then il make one with a smaller hump , or just leave it off , mind you hes daft enough already without sniffing petrol fumes out of his helmet lol cbt tomoz for both my lads so that's 2 of everything ive had to sort 2x mot 2x tax 2x insurance 2x full petrol tanks 2x helmets 1 full 2 stroke tank [ ones a vx 4 stroke ] and loads and loads and loads of pissing about with variators and daft belts and carbs they don't have a clue what they've let theirselves into do they??
