New Runner 172
Discussion in 'Scooter Projects' started by NrG172, Aug 5, 2008.
  1. Sw1fT
    Sw1fT Active Member
    200SX S13
    nah nobody on here has, as far as i know, minor probably has or has looked into it and some others may have bodged it, but because your bike is a minter you need to make it looked good or it will ruin the bike.
    what you can do is completely drain the coolant and make sure you are using fresh, correct ratio, coolant. If the temps are still up there you need to look into setting up a good double rad setup. Another thing you could do is use those inline radiators, the small ones, if you had one of those on each side of the water system, possibly somewhere visible or with good airflow atleast
  2. scottnrg
    scottnrg New Member
    end can
    sorry to go off topic but were did you get thta end can from cheers
  3. Dec
    Dec Active Member
    nothing ugm
    Re: end can
    mate he just answered that, its anodized so he got it custom made.
  4. NrG172
    NrG172 New Member
    Typh 178
    cheers for the help sw1ft... i found 2 radiators, one 125 one and a 50 one..the 125 rad i couldnt find anywheeereee to mount so i used the 50 one which just fits in below the original one... i also put one of them inline cooling things you were talking about on there and some proper coolant, the temperature is nice now doesnt get half a hot as it did..
    The end cans are anodised they come either in strips like that one or in little splashes sort of thing (like what this bike had on before , or even some of my other bikes might of had them if u can find the thread on here 'lees bikes') http://www.scootershack.co.uk/viewtopic ... c&start=30
    If anyone wants them done i dont mind getting them sorted for you, pm or something and i will give you details.
  5. Sw1fT
    Sw1fT Active Member
    200SX S13
    nice one, now u have a nice, cool, ported engine.
  6. RY4N172
    RY4N172 New Member
    Yeah lee the dotted end can dont loook half as good as the striped one mate . good luck at IOW too
  7. jay172
    jay172 New Member
    Two-stroke engines have a tendency to get hot or seize when the power is being reduced after a full power situation or a long run. At full power the engine may be able to overcome increasing friction of the expanding piston in the cylinder, but when the power is reduced, and the engine can no longer overcome the increasing friction, the engine gets very hot and potentially can seize. What you need to do is or blip the throttle a lot to keep the cylinder cool at the traffic lights or better still find somewhere where you can pull over and turn it off allowing it to cool down.
  8. Sw1fT
    Sw1fT Active Member
    200SX S13
    the level of throttle or engine rpm has nothing to do with the cooling of the engine in lees case, electric water pump provides the same flow regardless.
    if you're going to make your first post a preach like that i think you should atleast give reasons, why does the power being reduced mean the engine increases in temperature?
    im not trying to shoot you down, i know what you're saying, you just havnt said it very well at all and for your first post you're coming across quite badly, i would introduce yourself first.
  9. james
    james Member
    It's a shame kevin aint a member on this site he would be your man to ask on this...He used to sprint at x-race and had a 35bhp dragster that ran on a electric water pump and that engine was frezzing it NEVER was hot ever the pipes engine everything was ice cold but the pump was loud well a bit but used to work better than any cooling system i ever saw on a scoot...Lee you need to try and find out what he was doing as it can be done right?
  10. MiNoR cOnFuSiOn
    i belive he was running somthing like a 2000l an hour pump hence moving the water VERRY quick.
  11. james
    james Member
    Yeah maybe but all i no it was cold as fuck like ice cold and it always was no matter how long the engine was runing for i think he had the same system on his red glitter runner aswell....
  12. WOLFFY
    WOLFFY New Member
    Hmm.... I may have to look into buying one of these, on my £38.76 budget :w00t:
  13. NrG172
    NrG172 New Member
    Typh 178
    well i got insured yesterday and went on a little drive, got to the lights and felt my barrel was quite hot and i needed petrol anyway so i pulled into tescos... checked my mates barrel on his runner and his was like twice as hot as mine, i think im just getting paranoid of it over heating for some reason, seems to be running nice apart from jet is slightly wrong, might try a 108 instead of a 110. :cool:
    Got mot on tuesday so i might actually be legit on it :D does anyone know if my headlights would be a problem for the mot?? i think as long as there not too high it should be ok???
  14. RY4N172
    RY4N172 New Member
    Yeah they have to be adjusted ones ( standard ones )
    Slip the mot guy a tenner im sure he will pass them
  15. RY4N172
    RY4N172 New Member
    Lee
    have you changed your waterpump yet ?
    there is some 1 selling 1 for 15quid mate
    off a mercedes ? bosch 1
    talk on msn if you want it .
