need some advice please
Discussion in 'The Workshop' started by Jog_RR_madhead, Jun 23, 2017.
  1. Jog_RR_madhead
    Jog_RR_madhead Trainee bike mechanic in need of assistance
    Direct bikes Lynx
    Hey guys
    I was drastically losing compression on my new 50cc cylinder barrel. so I replaced the cylinder bolts which have stripped the thread in the engine. I just need to know what you guys think would be the best thing to do to get this problem sorted out....
    Size M7 helicoil or tap and die to Size M8? All help is much appreciated.
    Trev
  2. Stevep
    Tap and die to M7, no need to go to M8.
    Hate helicoils
    Buy new M7 studs
  3. Jog_RR_madhead
    Direct bikes Lynx
    its already on m7 but it's threaded so need to make it slightly wider.
    any other suggestions?
  4. Stevep
    Then M8 x 1.25 tapped.
    Start with a number 2 tap then a plug (No:3 tap) to get the threads all the way to the bottom.
  5. Jog_RR_madhead
    Direct bikes Lynx
    great thanks mate. I did what you said and got a result "nice one pal" but I made the mistake of buying carbon steel instead of stainless. I put the engine back together and back on the bike to find out that I was losing compression AGAIN grrr lol
    it turns out that the carbon steel m8 rod at the top of the cylinder head had completely threaded so I bought some stainless steel rod to replace it and put it all back together and hope it works. I'll post the results.
    Cheers mate
    CGC likes this.
  6. Jog_RR_madhead
    Direct bikes Lynx
    no joy lol got some helicoils coming tomorrow so hope they work
    will post results
  7. Stevep
    HUH?
    You've stripped out the M8 thread you tapped?
  8. Jog_RR_madhead
    Direct bikes Lynx
    it's sorted now anyway I'm getting between 100-130 psi compression but i think the problem now is fuel, the bike starts but whenever I apply throttle it bogs down and wants to stall. I have set the carb air fuel mixture screw by closing it then turning it 1 and a quarter turns out then 1 and a half turns out for the idle. it starts but I get a chugging sound coming from the exhaust and get no acceleration the back wheel won't even turn and I don't understand what it could be I've tried everything hhellpp! cheers in advance
  9. Tamiyacowboy
    Tamiyacowboy Pippa's Owner
    Piaggio Skipper
    come out more on the idle mixture screw im not sure on the Jog , but i can tell you some piaggios need around 2 and 3/8s out on the mixture screw as stock, some as low as one turn out.
    start at 1 1/2 turns out, add throttle slowly shut down throttle tweek the mixture screw again by 1/4 turn, try throttle again, if it dont play ball, shut throttle down , tweek the screw setting by another 1/4 and try again.
    WRITE down what you do, ie
    starting at 1 1/2 out
    adjusted to 1 3/4 out
    adjusted to 2 out
    this way you know exactly what you have done and if need be can revert back to stock just following your notes in reverse
    Jog_RR_madhead likes this.
  10. Jog_RR_madhead
    Direct bikes Lynx
    excellent thanks mate I'll do that tomorrow
  11. Tamiyacowboy
    Piaggio Skipper
    you may also need to check the main jet has not blocked up if it gets blocked it can cause some of the symptoms your are having to , check out retrivals speedfight 100cc problem i talk you through cleaning the main jet, its the same for almost all carbs from small 12mm all the way upto monster 28mm carbs and bigger
  12. Jog_RR_madhead
    Direct bikes Lynx
    hey I have upgraded to a 19mm racing carb with an 80 jet (brand new Naraku)... the bike still runs the same I checked everything prior to installation. I have a feeling it might be something to do with the 2stroke oil pipe that comes from the engine as it was pumping out oil from a crack near where it goes on to the carb
  13. CGC
    CGC Active Member
    Piaggio Liberty 50
    the back wheel does turn freely on its own ?
  14. Tamiyacowboy
    Piaggio Skipper
    this needs looking into if thats the case, whats happening is your running lean on oil and the bikes overheating due to lack of lubrication.
  15. Jog_RR_madhead
    Direct bikes Lynx
    the bike is running fine now it's a bit high on idle but that's the only setting I could get it to start at. the bike is now For Sale for £400.
    it has had everything replaced.
    will post a full listing of what its had later. thanks for your help
  16. CGC
    CGC Active Member
    Piaggio Liberty 50
    do you find any difference from the old carb to the new
  17. Jog_RR_madhead
    Direct bikes Lynx
    yes the new one was faulty lol the old one is back on now and its working fine it turned out to be the air fuel mixture screw lol
  18. CGC
    CGC Active Member
    Piaggio Liberty 50
    Ha, I was asking because I'm playing with the idea of putting a 17mm manual choke carb on the suzuki.
    was wondering what sort of difference the bigger carb made.
