hi all I have a paggio zip with a Malossi 70 kit on with a 21mm carb and a stage 6 exhaust I have just put the same top end on that was on before that ran mint before it blown up then I cleaned everything out and I have started it up and it seems to not return to idle after revving it I presume it’s the mixture screw but I am unsure Please could anyone help thanks
Normally thats how they are. But you need to set it not static too, as in, turn it in or out with the bike running
Im guessing its too lean, depending on where the screw is, depends on if turning it in makes it richer or leaner.
On this one its a fuel screw, turning it out, lets more fuel in https://www.pedparts.co.uk/product/1120/stage6-dellorto-21mm-race-carb-black-edition#
https://www.pedparts.co.uk/product/2174/12mm-2-stroke-moped-carb-with-auto-choke And this one its an air screw, turning it out lets more air through.
Thanks for sending the links mine was the first link I have got it running alright it still take a little bit to go down to idle but it’s a lot better than what it was also I am trying to change the oil and I can undo the dipstick but can’t seem to find a drain plug ♂️
