Scooter Shack Scooter Forum
ForumsThe Tuning CenterScooter Tuning
Need Help jetting problems Piaggio nrg
Discussion in Scooter Tuning started by Nrg01, 25 Apr 2011
Nrg01#1
Hi, i have a problem with my ped,i brought it not so long ago, a piaggio nrg mc3 extreme 2001,it started of as the guy i brought it of told me that 'only the piston had gone' that wasnt the case as the whole engine had gone due to him having a 79 jet
inside,i brought a 2008 nrg engine and put a pm tuning 70's kit on it as 50's would bore me,anyway,when i started it i found that i had a problem with the carb..when i throttled it would cog up and conk
i have standard air box on it, as i said it has a 79 jet inside it,someone said it maybe over fueling? if someone could help me find what jet i should have for a 70's kit with standard airbox on a piaggio nrg mc3 extreme..thanks - kyle
scott15#2
standard jet is a 53.
Are you running an aftermarket exhaust aswell?
check the jetting guide to see how much you should be upjetting by.
just derestricting it i would put in a 55 jet as it runs slightly lean otherwise, so make room for this aswell when calculating what you will need.
order a jet set for it, start by over jetting around 6 over what your calculations say, and then plug chop, working your way down till the sparkplug is a brownish colour.
What Roller weight do I need?2 replies1 May 2011
Piaggio Zip 50 into 1724 replies29 Apr 2011
best 70cc variator3 replies28 Apr 2011
Aerox mhr rep with yasuni c21 problems1 replies27 Apr 2011
What would be the best 70cc exhaust?3 replies27 Apr 2011
fastest 50 aerox setup1 replies24 Apr 2011
what 70cc kit should i buy?2 replies23 Apr 2011
Gianelli or Leo Vince TT?2 replies22 Apr 2011
aerox 70- what crank to use MHR Rep 70cc kit1 replies22 Apr 2011
2001 Aprilia engine 50cc5 replies21 Apr 2011
