My vento zip build
Discussion in 'Scooter Projects' started by waxhead, Jan 17, 2008.
  1. waxhead
    waxhead Member
    thanks man
    I just brought an aerox last night so i guess most of the developement is going into that now
    I think the vento will stay the way it is now
    I am about to order an mhr rep kit with a 21mm dellorto that i have already
    And a good pipe
    I want a scooter that wants to power stand off the light
    Not sure if an mhr rep will have enough grunt to make it to that
  2. kyle1b1
    nice pipe :punk:
    a rep will definatly make it power wheelie off the line.
    my ice did with just a mhr-rep bolted straight on with a 19mm carb and a tt pipe.
  3. Jamie
    waxy axey head, are you fabricating your own endcan aswell or using one from another pipe? :D
  4. waxhead
    waxhead Member
    Im not sure on that one yet
    i will more than likely make my own end can
    Just make the alloy end cans on the lathe at work
  5. waxhead
    waxhead Member
    Well my water pump and radiator turned uptoday
    now i just have to find a way to mount them
    that shouldnt be to hard
    I started work on my swingarm today to try and removed the locating bolt inbetween the mounts
    This will allow me to run a rearward facing carb
    And started to also fit my hpi ignition system
    Should be good when its all going
  6. waxhead
    waxhead Member
    well here is some pics
    this is my swing arm not finished of course
    in the other pic you can see my water pump i am going to be going for a water pumper engine now
    Also you can see expansion chamber wall
    HA ha
  7. Dec
    Dec Active Member
    nothing ugm
    the front wheel looks sweet and loving the hall of exhausts :D
  8. MiNoR cOnFuSiOn
    keep up the good work m8, ether the rep with a single ring piston and a fair bit of grind work or buy an evo..., evo is the best power/money yuou can get an theres no need to further port it. you WILL be impressed.. remember to make the can longer than needed an trim back as you tune it.. will be a magic length that just works right.
    if you however arew up to making a pipe for the rox im sure somone will give you dimentions of there pipe (prefebly a c16/c21 depending on the barrel)
  9. waxhead
    waxhead Member
    As you can see i have done a bit mor
    ei m aboxing in the sides of swing arm to give it some ridgity
    Its looks a bit rough at the time but i assure you when its finished it will look just fine
  10. MiNoR cOnFuSiOn
    if i were you id be welding that bolted into a jig... amazing how much they can distort wiht a bit of heat...
    keep it up as always tho.. get that pipe finnished too.. i wanna hear it :D
  11. waxhead
    waxhead Member
    Dont worry its been held when i am welding it
    I have a jig of sorts, im not welding it there on the carpet Ha ha
    yeah well pipe is on hold while i get the engine back together
    BUt then its full on
    waiting for my new cylinder to turn up as well
  12. waxhead
    waxhead Member
    Well my swingarm is finished now
    All painted up and ready to go
    I will fit it omorrow and then its hurry up and wait for the other parts to turn up so i can put the rest of it together and get back to terrorising the neiighbours
    Opps thats right i need to make a new intake
    thats easy
  13. waxhead
    waxhead Member
    Well my ignition is all mounted
    just have to wire it in and away we go
    Will be interesting to see what a good timing curve does to this engine
  14. MiNoR cOnFuSiOn
    lookin good m8, will be watchin this one :p
  15. waxhead
    waxhead Member
    Thanks man
    Yeah i cant wait to get it going
    Waiting for the cylinder to turn up and then its away we go on the build
    i ma just turing up wooden cones to help me to make a better job of the pipe
    its not as good as i would like it so i will remake the cones
  16. Boost ya scoot
    Boost ya scoot New Member
    hi mate
    what exhaust are you going to be running with the hpi...... and what timing have you set the hpi to?
    Cheers BYS
  17. Sw1fT
    Sw1fT Active Member
    200SX S13
    had you read the whole thread and actually taken an interest, rather then simply asking questions for your own benfit, you might have found the answers by yourself.
    READ
  18. m1ck_t
    m1ck_t Moderator Staff Member
    alot of shit
    waxhead have you got them pics of the modded air box mate? looking to fo thhe same to mine and just want to see how it's done properly.
  19. MiNoR cOnFuSiOn
    do yourself a fav... fuck wood.. go grab a few diff size traffic cones an fill with cement.. pull it out an you got a heatproof form ;)
  20. waxhead
    waxhead Member
    I aggree that sounds good
    but these are at the perfect angle
    I just have to finshe the other 3 and i will be ready to go
    i will bend them around these and then tig them while they are on there and remove them
    Tig is so localised heat it will be fine
