my bike is winding me up ....
Discussion in 'The Workshop' started by Hursty, Jan 27, 2007.
  1. wobbly_trials
  2. Nrg-Jay
    Nrg-Jay New Member
    What carb i meant as stock, Sorry :emb:
    12mm del ? 17.5mm del?
  3. wobbly_trials
    ah right, tbh i'm not sure, whatever the rox, area51, sr, f12 and f15 come with.
    i beleive they are 14mm but not sure.
  4. Nrg-Jay
    Nrg-Jay New Member
    Ah ok, as i know the later aeroxs came standard with the 17.5mm delorto same as the mc3s
  5. wobbly_trials
    ah right, but the minarelli is a different motor than the nrg so jetting will be different?
  6. Hursty
    Hursty New Member
    ill get a box of jets i suppose.. its a delorto carb ..
    yeh but its derizzed and running a derizzed pipe thats all so.... :bird: :wtf:
  7. wobbly_trials
    most probably the same as my 02 area51 as that runs yamaha electrics. just do a plug chop, take it for a ride then check the plug colour, if its chocolate its good.
  8. Hursty
    Hursty New Member
    plug chop?? its running like a digestive biscuit colour LMAO
  9. wobbly_trials
    slightly lean? coffee or chocolate brown colour is good (not white chocolate, holes start appearing in your piston) whiter is eaner, darker is richer
  10. Hursty
    Hursty New Member
    So i wanna downjet it a little ?
  11. wobbly_trials
    i would say upjet, looking at a digestive now and its lighter than a twix. lol.
  12. Nrg-Jay
    Nrg-Jay New Member
    You carnt always rely on plug check !, as your idle mix maybe out, and many other things.
    If its wet and black running rich, if its got a choc firing tip then that is fine, but dont always rely on plug reading :)
    Hursty get on msn :D :w00t:
  13. Nrg-Sam
    Nrg-Sam Active Member
    the carb on my rox is a 12mm dellorto, the jog has a 17.5 mm i think? thats a later model tho with an autochoke :nerd:
    like i say ive got the same exhaust and the same problem so i doubt weve both coincidentally got a bit of dirt in the carb rofl :pimp:
  14. Nrg-Jay
    Nrg-Jay New Member
    Hurst should be sorted now helped him out an sent him some stuff, so he might be willing to pass it on ? :pimp:
  15. Hursty
    Hursty New Member
    yeh lemme do it all first and sort it then ill get back to u sam :D
  16. SR-STEF
    SR-STEF New Member
    im sure my sr is a 17.5 delorto mines 1 of the early 1998 minerellis
  17. Hursty
    Hursty New Member
    ok just a lil update on this.. i got it running agen but.. it still leaks fuel even after i replaced the fuel tap and the float set ????
    when the bike is running .. the float isnt stopping the fuel so it drips out when running .. then when i turn the bike off. what ever is left in the carb and fuel hose just drips out..(whats left after the vacuum)
    any help... ??/ im so fucking confused.. it might have to go in the shop tomoz.. and i dont really wanna waste my money :D
  18. wobbly_trials
    it's got to be the drain at the bottom of the carb, or the seal between the bowl and the carb or the float valve
  19. Hursty
    Hursty New Member
    well i mean i just changed the needle :confused: so.. it cant be that.. ill try to do every bolt/ screw up extra tight... :cool:
  20. Hursty
    Hursty New Member
    actually i just thought.. the drain screw maybe shagged.. and just letting the fuel through :wtf:
