Thanks alot mate i have written it down so i will be ordering that soon and is the malossi multivar any good and delta clutch lol
https://www.pmtuning.co.uk/Merchant2/me ... 050AREOXLC I would go for this kit...polini speed control...you get the variator..belt and contra spring and rollers...cheaper than buying it all seperate although shop around...p.m arent always the cheapest...that price is without vat and p@p!!!
yeh cheerz mate thats what i will get then malossi mhr 70cc, c16 exhaust, malossi 21mm carb and the polini speed kit and the bgm pro evo crankshaft what bhp do you think i will get after i put all this on.
A lot more than std ..........should be pretty quick....you may need a gear up kit too...depends if you want real quick acceleration or good top end!!
The clocks on 50/70cc scoots are highly innacurate anything over 30/40mph :w00t: youll deffo need a gear up to acheive over 60mph...but your clocks will be reading about 70mph at 60 anyway :wtf: with std gearing and that set up youll have a 60mph wheelie machine
yeh lol i wont bother with the gear up kit then and my aerox at the minute has 200miles on it cos am running it in how many miles before i can put all that kit on thanks
if your changing the crank it dont matter...the only bit your keeping is the cases... just stick it all on now and run the kit in
What about the warranty my first service should be at 500miles so should i just get it done somewhere else lol and do you have msn mate cos if i dont no something i can ask you lol
ok so i am on scooter-attack.com now and this is in my checkout cart ready to order: VARIATOR POLINI SUPER SPEED KIT €101.52 Mainjets Dellorto 5mm size: 040 €1.88 POLINI CARB-KIT 21MM €93.54 YASUNI C16 RACING €236.88 CYLINDER KIT 70CC MALOSSI MHR REP. €185 I still have a little money left to spend tell me if you think i should get anything else
selection of rollers... clutch spring set... jet box (selection of main jets size 70-90) mono petal reed block... http://www.scooter-attack.com/index2.ph ... navigation
The rollers and clutch springs come with the polini super speed thats why i choose that and i will look at a mono petal reed block when i get the reed block should i order it
The clutch springs dont come with it....thats a contra spring that comes with the kit And the rollers may be a little heavy in the kit for your set up!!
yeh the rollers but this is what is say:In addition to the already known parts of the Polini SUPER SPEED, this kit also includes a drive belt, a fixed front pulley/ fan wheel, two torque springs, two sets of roller weights and - for Minarelli engines - an additional clutch spring set. This set will save you some money! it says an additional clutch spring set
http://www.scooter-attack.com/index2.ph ... navigation ahh i see you went for the 9 roller kit...i see now The problem is you dont know wether the rollers and springs are gonna be ideal for your set up!!! Really you want a selection of rollers and springs to play around with for the best set up Im not sure about the 9 roller set up ive only ever used 6 roller variators (less rollers to buy i.e cheaper)
ok so what should i go for cos i no nothing about bikes am just buying what you tell me then taking it to a shop to get the kit put on lol just send me all the links of what to buy but go on scooter-attack they are cheap lol
yeah i tell you what...when ive done all that i"ll pop round and make you a nice cuppa as well :w00t:
This is what i have decided to order just tell me if you would change anything cos you no your shit lol INTAKE MANIFOLD, DERESTRICTED €14.46 POLINI CARB-KIT 21MM €93.54 Polini Clutch springs for original clutch €11.57 Variator Polini SpeedControl 2003 €60.75 MALOSSI X SPECIAL KEVLAR BELT €21.21 YASUNI C16 RACING €236.88 Mainjets Dellorto 5mm sizes: 70, 72, 75, . 90 €16.39 CYLINDER KIT 70CC MALOSSI MHR REP. €185.15
