Malossi 172 Cylinder with Stock Cylinder Head?
Discussion in 'General Tuning' started by Malossi Tom 172, May 8, 2020.
  1. Malossi Tom 172
    Malossi Tom 172 New Member
    Hi chaps,
    Can anyone tell me why some of the Malossi kits come with no cylinder head..? Does this mean you can bolt the barrel to the stock cylinder head..? If so are there any issues with this such as inferior cooling / heat dissipation or will it be fine?
    If it makes any odds, the scooter in question is a 2003 Aprilia SR 125 Air Cooled.
    Ta :)
  2. milo2025
    milo2025 Trip to Trumpton
    Hello bud that's basically correct and it will save you money too. Shouldn't be any issues as long as you have the right tools and it's done properly.
  3. MARSH
    No, it's wrong size. std is 55mm, Malossi is 65mm. Compression will be to high and piston may hit head.
