Also... I'm running premix now as I didn't want to risk the 18 year old autolube destroying my engine so a got this to measure the 2stroke accurately
Great work on this, looking really good! How do you rate the rear shock? Looking at one of these for mine but not sure if its worth the extra over the YSS Pro-X? It certainly looks nicer! Have you fitted Renthal grips?
Thank you pal.Yea Renthal grips fitted,the shock was worth every penny! It's fairly soft tho even on max stiffness not that it poses a problem. plus I do way 14stone lol
Cool, thinking of going for the renthal kevlars on mine as can get them in the larger 32mm size, though I like the grey ones better colour wise! Always reminds me of race bikes. Anyway they should take care of the little vibration I get through the original near solid grips!! Shock sounds good though odd it doesn't go that firm, guessing it's still harder than the original though? I'm planning on going the opposite route to you regarding premix.. currently I'm running autolube and premix - annoying, I want the simplicity filling up at petrol stations without messing around with oil at the pump. so the plan is to buy a new genuine pump with all new pipework and have the pump turned up a bit to make sure everything is safe. I figure my original pump has done a good job for 15k and 18 years so can't see why a new set up won't do the same again. Whats next on this project?
Yeah the grips are comfy tbh. the yss is much stronger than the original and yes it's stiffer I'm really pleased with it and as for the looks it gives the bike. you should def get one as for the auto lube if you get brand new you'll have no worries earthier way if you get new of premix it'll be fine. It's not so bad for me with oiling at pumps as I only fill up once every 2or3 weeks as I just use the bike as a pleasure thing so full tank lasts weeks lol. As for what's next iv got a few tasteful mods up my sleeve I'll be sure to post the pics. by the way your bikes very clean around the same year as mine I believe?
You guys get all the cool looking scoots over there. We're stuck with all the crap they can't sell anywhere else
Looks like your brake cable is stretched, or shoes are worn, or the back lever thingy is put on wrong? Tidy looking scoot.
Not sure I dont think so tho fella it seems to work great and it's just past an mot 3weeks ago (no advisories)
What makes you think it's bolted on wrong.there's only one way it gos isn't there ? How would you have it bolted? if you could elaborate?
On other news had to do a 40mile round trip today on the malaguti premix seems to be running great, I pulled the plug when I got home and was looking ok, did have a num bum tho lol
What he means is there is far too much thread showing on the adjuster. Either the cable is the wrong one for the model or the lever is on the wrong splines. I don't know the model but usually you can unbolt the lever and move it back one or two splines so that the adjusting nut is nearer the end of the threads. As it stands it looks like you have little or no adjustment left as the shoes wear. It should look something like this with new shoes.
Thank you for elaborating. you can indeed move it back on the splines i have just done it....not sure it's made much difference other than now having less thread showing lol, brake feels as strong as before Oh and the make is malaguti it's Italian if you are curious
