Little bit consfused
Discussion in 'The Workshop' started by Major Rel14b1lty, Jun 12, 2007.
  1. Major Rel14b1lty
    Major Rel14b1lty New Member
    ok well ive been riding it rather hard. like full throttleing but not for long periods.
    Seems to bog and full throttle cant work out if its lean or rich, ill have to do a plug chop tomorrow.
    Did once ealier and it was chocolate brown.
  2. wobbly_trials
    yeah, make it bog for a few seconds then kill the ignition and lock the back wheel to stop the motor, then do a plug chop.
  3. MiNoR cOnFuSiOn
    more tea sir?
  4. wobbly_trials
    nope, more castrol R
  5. Major Rel14b1lty
    i use some castrol fully stuff and malossi 7.1 or 7.3 cnt memba.
  6. capri dave
    capri dave Active Member
    ive always ran my scooter on castrol TTS fully synth..
    when i fitted my bore kit a few weeks ago the original 49cc piston
    didnt even have the slightest score mark on it, even after 20,000km!!
    And the barrel was unmarked as well...I was shocked :w00t:
    Think thats reason enough to carry on useing TTS oil :D
  7. Major Rel14b1lty
    lol might have to get some of the stuff.
    Blimey the bike is really fast, hopefully when i fit clutch springs and torque drive ill be able to get front wheel up a bit better?
    What you think?
    Im going to try and get some videos
  8. MiNoR cOnFuSiOn
    deffo once you got the springs in there it will be alot better
  9. Major Rel14b1lty
    its already got blue clutch springs in and my uncle said they were never changed and my cousin never changed them.
    Does the colour mean nothing, i have some blue ones and some green ones.
    Got the front wheel up for long earlier lol
    i think the blue ones came with the tt but my cousin never fitted them because there were blue ones in already.
    is the torque driver even going to make a noticeable differnce with a standard variator?
    i know this is a long post but also how do i turn the oil pump up because at the moment im putting bit extra in with my petrol
  10. capri dave
    there you go m8 ive done the leg work for you, regarding turning the oil pump up :D
  11. Major Rel14b1lty
    yer ive read that but i dont know were it is or looks like.
    Im going to go and follow my oil lines ;)
  12. capri dave
    Oh right... at the front of your tranny caseing theres a rubber bung.
    lever the bung out and peer inside, and you will see your oil pump.
    you will also notice the cable going through the caseing with an adjuster.
    when you look at the pump...get an assistant to twist the throttle open on
    the handle bars...and then you will see the crescent shaped cable linkage.
    It will all make sense when you get this far.. you want the flat on the side
    of the crescent shape (where the cable is) to be pointing straight up in the
    12 oclock position ;)
  13. Major Rel14b1lty
    okey dokey cheers mate, so when i take my tranny casing off its the thing on the left.
  14. Major Rel14b1lty
    by the way when the bike is idling should the oil line be full, cus i took it off the carb and hardly any oil was going through, it was like dripping through.
    When i got back from a good old raggin it was green though so it had been pumping it through i think.
    p.s my malossi oil is green
  15. wobbly_trials
    yeah it only uses about 1/50th of the ammount of petrol it uses, for every 5l of petrol through the engne, only 100ml of oilgoes through, it wont flow into the motor.
  16. capri dave
    yep thats it...but you dont need to take the whole caseing off to adjust the pump..
    just lever off the rubber bung and thats an inspection hole ;)
