OK, silly question if i'm replacing rollers with the same weight how will that give me more speed pls?
keeping the standard roller in will keep it the same as standard as in take of and how quick it get up to speed so it will keep the gear changes the same grinding down the washer will increase your speed as variator itself will be able to move further then usual lighter rollers will give u less top speed but will give u better acceleration and the bike will rev higher heavier rollers will give u more top speed but will take longer to get to speed it will be getting lower revs
OK very helpful, so I think I should.... 1, grind down the washer and re-fit this new ECU and see what that does firstly. If the bike still does not speed up a little fit some rollers. My question is what roller as in weight should I fit pls?
Iv just put 3x6g and 3x7g in and got 39mph on flat id say with that it goes ok i have got a vid if u got WhatsApp i can send u it
I’ve got a lexmoto nano and I couldn’t find the cdi but that picture you posted I could find, did replacing it derestrict your bike?
