Leaking oil
Discussion in 'The Workshop' started by SimonT, Dec 14, 2006.
  1. SimonT
    SimonT New Member
    Im leaking oil from the bottom of the oil tank.
    i got under there last night and tightened up the hose clamp, and the other clamp holding the hose fitting.... still didnt stop it....
    has anyone else had this problem?
    Thanks
    Simon
  2. MiNoR cOnFuSiOn
    there is a small rubber o ring on the metal pipe fitting once removed, this is probably the fault.. are you sure its not comming from the top where the oil sender/level sencor is as it can pop out of place and oil will come out and dribbel down.
  3. SimonT
    SimonT New Member
    i dont think so, but ill double check this....
    The other clamps are tight, so it might be a possibility......
    Thanks
    Simon
