Been on ebay. Thire is only 1 jonway engine on thire. But no guarantee it works as sold as spares or repair. And I don't no what other chinese engine will fit. All I want is a running engine. That will go in the bike. And don't want to spent silly money on a new one
Iv put 2 new new top ends on it replaced almost everything on it. So just don't move just bogs now has developed well when runng sounds like a hammer beating against something inside verry loud. Iv just had it with this engine. That's why I just want to replace with witch I no from day one was working fine
Ok sounds like a fuel issue. And maybe the cam chain... But yeah I understand you. Peugeot v clic uses the same engine I think. It's honestly a really common 4t motor.
I don't really want to touch this engine anymore iv put to much money into it. I really want to just buy a running engine. And bop it in. Job done. Started the bike today fires right up clunking sound has gone but half throttle starts to bog. So you got to come back off the throttle if you can get it to full rev. It judders and don't. Move when you sit on it.
OK manniged to sort it out it now runs and rides. But the funny clunking sound. Has got ton bad could it be becose I'm useing 10w30 oil
Found out it was the magneto can't think of that it's called the thing that the fan is attached to had came loose. Tighenedit back up now bike is a bitch to start
That's what it is called the flywheel was bouncing around. Tryed pulling it off but no luck. So will try tomorrow. So is that why it's hard to start now as timeing is off as I just tightened the nut back up. As I no it needs to be tdc
