Italjohn's Typhoon project 172
Discussion in 'Scooter Projects' started by italjohn, Dec 8, 2007.
  1. italjohn
    italjohn Member
    I did order the adapter for the Typhoon, and as you can remove the two spacers, I think it will fit the original disk.
    I have not tested this, so I can't garantee anything.
    I have checked the text, and it will fit 190, 240 og 280mm disks.
  2. italjohn
    italjohn Member
    Yepp me too, just look at your avatar :D
  3. italjohn
    italjohn Member
    I was going to change the variator today, and think I should use the old Runner variator.
    A discovered that the old Typhoon has a spacer just inside the variator.
    This spacer is "build in" the Runner variator, with the result the this wont fit unless I modify the oilbelt cover.
    Series 3 engine. Look at the oilbelt cover.
    Series 1 engine. Much smaller hole in the oilbelt cover.
    Here are the variators.
    The question is:
    Can I use the back plate on the original variator, and svap this with the Runner variator back plate?
    Or is it best to modify the oilbelt cover?
  4. italjohn
    italjohn Member
    I did also installed the new forks today.
  5. TIddLY_TyPH
    TIddLY_TyPH New Member
    project is coming along nicely cant wait to see end product
  6. MiNoR cOnFuSiOn
    that sure is an old style variator... as for using the runner one? there THE SAME m8, no point
  7. italjohn
    italjohn Member
    Now I have install my new parts washer, and a new shelf.
    What do you think, could come in handy ;)
  8. Miyo
    Miyo New Member
    johnnnn
    u gotta finish this project, im excited for u ^_^
    cant wait to see end product!
    keep it up m8 5/5 :cool:
  9. MiNoR cOnFuSiOn
    bike and workshop are comming together nicely :D
  10. italjohn
    italjohn Member
    Well I'm waiting for a BIG box with new parts from Scooter center, and some parts from German Ebay.
    Updates will come as soon as the parts has arrived :D
  11. italjohn
    italjohn Member
    Re: My Typhoon project 172
    Than the pallet from Germany has arrived :D
    I have got new panels + some special tools, and vents + seatcover + front for my Runner.
    And a lot of wheels :msn1:
    Panels sanded down, ready for painting next weekend.
    Sorry about the mess in tha background.
    Some wheels to play with :D
    I have also converted the loom to the new NRG Power/Gilera Runner dash.
    Everything seems to work so far, I'm exiting to see if the rpm meter will work aswell.
    This we will know when the engine is back in.
    Some Runner parts :p
  12. nrgandy
    nrgandy New Member
    the clock look good ive been wanting to do it for a while now. was it hard to rewire?
    projects coming along good
  13. italjohn
    italjohn Member
    As I have the Hayns manual + the original wiring diagram for the NRG and Runner loom, it was a piece of cake. (You need a NRG/Runner loom to cut the connectors from)
    Only problem I have is that I need a connector for the light switch, as the 50 ccm don't have this. But this I will figure out some how later. I'm also left with the charger lamp, as NRG Power don't have this either. But I don't think I need this feature. (I will think about a solution for this as well.)
  14. MiNoR cOnFuSiOn
    the switch is simple as there is a cutout/easily made cutout for it. peice of pie :) can wire a switch for many diff stage lights off any power scorce to a headlight (if its constant) anythings possible light wise, im sure you can sort it
  15. nibbles
    nibbles Active Member
    were are u thinkin of puttin the vents m8
  16. billy #86
    billy #86 New Member
    on his runner i would of thought
  17. italjohn
    italjohn Member
  18. italjohn
    italjohn Member
    This looks promesing :D
    The paint shop (local Toyota shop)
  19. MiNoR cOnFuSiOn
    hey hey
    you know we love black typhs round here :D (seing as 2 of the 3 owners have em LOLOL) cant wait to see it all finnished. should be SWEET
  20. nrgandy
    nrgandy New Member
    looking good there just something about a black typh aint there shame mines going red again lol
