Italjohn's Typhoon project 172
Discussion in 'Scooter Projects' started by italjohn, Dec 8, 2007.
  1. italjohn
    italjohn Member
    I did bougth mine from Scooter center.
    And I don't know how restrictiv it is?
  2. MiNoR cOnFuSiOn
    supposedly 1 in 1 million particals... so fuck all basicly... good filters ;) point the holes up tho, entire point fo them LOL
  3. italjohn
    italjohn Member
    Any one know if this can be used for the oil feed?
    Product Nr.: PP1000 €54,-
    Intake manifold spacer kit -PRO PORTING- Piaggio - connection diameter 34mm for BGM PWK, Keihin PWK, Koso PWK and Dellorto PHBH carbs. With a little pressure it is no problem to fit carbs with an connection diameter of 38mm.
    Fits to all reed systems which are similar to the V-Force3 and Malossi.
    There is no need for the machining of the engine casings.
    Delivery contains fitting material.
    There is an option to fit a depressure pipe with M6 thread. Therefore you have to drill the holes to 3mm.
  4. nibbles
    nibbles Active Member
    might invest in one of them quite funky .why do you have to point em up then minor man
  5. MiNoR cOnFuSiOn
    nah its a good inlet.. just needs an angle shim in there to get the tract right.. or a slither of rubber going into the top of the reedblock to smooth it all out. would draw it but im lazy.
    and yes pre reedblock nipples can be used for oil or vac (diameter dipendant) post reedblock (engine side) is for fuel pumps and the like...
  6. Vesta
    Vesta New Member
    In all fairness it sounds like a 4t :emb:
  7. connor
    connor Active Member
    thats what i wanted :rtfm: . out of stock when i was ordering! how Gay looks so lush.
  8. Jamie
    just buy my 28 mikuni flatslide connor lol
    40 pound
  9. connor
    got one on order already.
  10. alexsr70
    alexsr70 New Member
    30??
  11. italjohn
    italjohn Member
    Some more pics of the new 28 mm carb in Black.
  12. capri dave
    capri dave Active Member
    john you are in love with that PWK carb :D
    I dont blame you m8....its sexy ;)
  13. Jefr0-180
    Jefr0-180 Active Member
    Nice looking carb ;)
    Clean that mudguard lol, cases would look good black with that carb :cool:
  14. italjohn
    italjohn Member
    Yepp, I was just thinking the same, so I will probably get the engine cover powdercoated at my work. The original cover needed some new paint anyway.
    And about the mudgard, you are absolutely right. But I think it need some paint, rather than just a good clean.
  15. Jefr0-180
    Now we're talking :cool:
    Will be keeping a close eye on updates ;)
  16. italjohn
    italjohn Member
    I have now dismantel all "loose" parts on the side casting.
    Will now have it clean and paint stripped, then powder coated black.
    The kickstarter axel is a little bent, so I had to knok out the bushing with the axel inside. Will try heating it, and then bend it back.
    As this is the engine I bougth from Ebay, it has a small damage as you can see on the pictures below. I don't think this will affect the strenght thoug.
  17. italjohn
    italjohn Member
    I was a little bored tonight, so I desided to open the old series 1 engine that is the original engine on the Typhoon.
    The castings looks ok.
    The variator does not look that good :msn1:
    The rear pulley is also showing some damage, but this looks "fixabel"
    Clutch looks brand new :D
  18. italjohn
    italjohn Member
    I did got my new brakes today. Everything looks realy good, but there is one fault, the disk is a little bent, so it catches the brakepads when I turn the wheel around. It's not much, about 1-1,5 mm but I don't think this is good enough, so I will send a claim to http://www.speedline.dk and hear if they can send me a new one.
  19. FirE
    FirE New Member
    172 oyster card beep
    iv seen that set up somewhere before but where :wtf: :confused:cratch:
  20. LEE
    LEE Member
    did you order the adaptor bracket ffor a typh will take adaptor take standard sized runner disc looking good btw :drool:
