Italjohn's Typhoon project 172
Discussion in 'Scooter Projects' started by italjohn, Dec 8, 2007.
  1. capri dave
    capri dave Active Member
    This page should be classed as scooter porn :pimp:
    im bloody dribbling here looking at all these goodies :drool:
  2. tErr0
  3. Jefr0-180
    Jefr0-180 Active Member
    Now that's sexy!
  4. FirE
    FirE New Member
    172 oyster card beep
    t3rr0 dont give him ideas you tart :w00t: ;)
  5. italjohn
    italjohn Member
    Yes! thats what we are talking about :cool:
    Do you have more pictures of this?
    Is it a 3 stud or 5 stud disc?
  6. italjohn
    italjohn Member
  7. italjohn
    italjohn Member
    I might have found the solution to the 12" and 13" wheel size "problems" on Typhoon.
    I did modifed the speedodrive, so it looks like the old one on the Typhoon.
    Now the 5 stud wheels line up perfectly, all it's need is a stage 6 brake disc and adapter. This looks promessing don't you think :D
    This is the original Typhoon wheel. The disc is parallel with the boss.
    Here is the NRG MC2 wheel, as you can see the disc is about 1 cm further in to the center. You will need a spacer to use this wheel.
    Here is the Runner 12" wheel, which has the same disc and speedodrive as the NRG MC3, with the modified speedo drive. :D
  8. italjohn
    italjohn Member
    I have been seaching for a airfilter solution, that is "closed" and have now come up with this as a possible solution. I don't think this solution will clear the rear damper, but will look into that later.
    Here is the 28 Stage 6 PWK carb, only pitty is that I did't order this verson.
    The correct one is on it's way :)
  9. connor
    connor Active Member
    air filter/box looks mental (in agood way ). what size carb is that?>
  10. italjohn
    italjohn Member
    28 mate.
  11. bait
    bait Active Member
    it looks huge lol
  12. italjohn
    italjohn Member
    Here is finaly the R/T versio ;) It's an early xmax here in Norway :D
    Whats in the box
  13. tErr0
    Not really seen someone trying to use a cart air box in the same place as the stock air box so that's pretty new. Normally they are just mounted under the seat.
  14. nibbles
    nibbles Active Member
    umbrellor corparation av tapped the carb industry now ,first zombies now thisps you may only understand this if your a nerd whos into shit zombie films like myself . carbs are looooooookin sexxxxxxxxxxxc m8 so you gonna sell the silva carb then
  15. italjohn
    italjohn Member
    I realy would like to keep the stock look, and most important try to keep the sound level down.
  16. italjohn
    italjohn Member
    The silver one is going back to the shop, as this was not my mistake.
    I have now got the one I did pay for :D
  17. nibbles
    top notch were u get that filter f rom and does it seem to be very restrictive ?
  18. Vesta
    Vesta New Member
    I got one a few months ago from donotlink pedstop think you can get em from scooter attack mate
  19. nibbles
    how restrictive are they more than a standard less than an open filter??
  20. FirE
    FirE New Member
    the black carbs sexy!
    im keen to see what this project turns out like might have to start mine soon.
    what colour you planing for in?
