I just got the forks today so you have to be a little patient. I have just discovered that I need a new protection plate under the steering bearing. About the caliper so do I have to make a spacer some how.
if you are using a disc that is bigger than a typh one tou will need an adaptor im having the same trouble with mine i think i will be using stage six caliper and adaptor kit as for the protection plate the shop i use this always comes with the set when i buy the bearings i think there rms ones
you have a 3 bolt disc nrg front wheel dont you? if so it should go on fine.. there made for a typhoon afterall?
There was no disc or adapter included with the fork. I think the adapter comes with a lager disk, the fork is design to work with the original Typhoon disc.
your have to try and find an oversize dis with adaptor for typh i remember whe i was trying to find one i could only find 2 and they cost shit loads more than a stage six caliper and adaptor if i remember correctly
Yes I have also been thinking about this Stage 6 brakes. I don't think this will fit the NRG wheel, because the disk is not in the same possission as the original Typhoon.
the easiest thing to do will be to put a typh disc on may look a bit small but will work spot on unless you want big front d on
Re: brake I have not seen any with a complete setup, but I found this on runner.net SIP has this one.
