Well, then I have recived my 125 rear Runner wheel. Now is the question: Shall I convert to rear diskbrake, or keep the original drum? I have to cut the brakeshoe pin, and it would be very difficult to instal a new one, so this is a one way road only.
im sure i read somewhere they have a thred on them i havent realy tryed to remove mine but when the time comes ill proberbly grind it off as im doeing a disk convertion like you
to get mine out i headted up the casing at the back, then whacked a socket peice on the pin, one slightly smaller, smash it in then twist it, it doesnt have thread but if u twist it the right way it will work its way out
Good old santa claus Tell me john is santa claus very early or very late arriving in Norway this year
heat and a slide hammer works wonders... if no joy heat a peice of wood and some pipe grips are golden
I just found my "user manual" for my Polini variator, and this has this spacing washer that you talking about.
Fitting this silent block turned out to be a pain in the ass. I had to make my own "puller", than it just "slide" in easily.
Now I'm almost finished with my rear disk conversation. Here is a preview 2 pc. of VX 125 brake master cylinders.
hi italjohn i have been trying to replace my silent block on my gilera runner fx 125 and i have been doing it the same way you have with the pully system and it wont go in have you got any advice
