Italjohn's Typhoon project 172
Discussion in 'Scooter Projects' started by italjohn, Dec 8, 2007.
  1. LIVELY16
    LIVELY16 New Member
    i think its shit ................................................................... hot its lookin wiked keep up the good work
  2. TIddLY_TyPH
    TIddLY_TyPH New Member
    Really looking good mate :cool:
  3. connor
    connor Active Member
    lookin mint mate keep it up :cool:
  4. italjohn
    italjohn Member
    Finaly the "new" engine arrived from UK.
    I did pay £100,- for it, and I think that was a "steal".
    It has some major scratches on the side cover, and it misses the vacuum outlet to the gasoline tap. Beside from that it looks ok.
    Realy looking forward to start workin on it. :D
  5. connor
    i know this a bit off topic tell me to fuc off if you want lol. but you see the rubber bits on the top end, do you actually need them on ?
  6. Sw1fT
    Sw1fT Active Member
    200SX S13
    theyre for soundproofing and to be honest, no, but why not use them if theyre there?
  7. connor
    oh ok fanks. no its just when i put my 172 on some of them snapped soi didnt put them all on just makeing sure that it wouldnt do any damage. fanks though. :beer:
    SORRY FOR SPAMMMING :emb:
  8. italjohn
    italjohn Member
    I did finaly get the side casting off. This motor can't have been opened sinse it was new.
    Here is a look at the inside.
    Oooo look at that color!! Here it must have been very hot.
    Here you see the broken vaccum outlet.
    Not to good
    Here is the Typhoon variator and the Runner variator side by side.
    Do not look the same??
  9. Haresign
    Haresign New Member
    GPR50 + Peugeot 307
    that clutch has been hooooooooot! looks cool though. were the pads fucked or something?
    could you run a direct feed straight from the petrol tank straight to the carb or do you need the vacuum pipe??
    if you need it, how you going to go about sorting the broken outlet??
    sparkplug looks like it's had too much coke :cool:
  10. MiNoR cOnFuSiOn
    the vacum pipe fitting pushes out from the inside.. just push hard with a croshead screwdriver..
    the variator without the screws in the back is a 180 variator
  11. italjohn
    italjohn Member
    Here is a picture of the clutch.
    Does look ok to me.
  12. MiNoR cOnFuSiOn
    lay the clutch on a peice of glass... also rest it on a level surface open side up and lay a spirit level across each shoe pin/shoe body... any difference in any shoe ditch it..
  13. italjohn
    italjohn Member
    Ok that is good news is't it?
    The previous owner must have change it some time ago then :)
    Oho i just remembered that Beed speed has a weight over view, and I measured the weights to 19x17, which means it is a 125 variator.
    http://beedspeed.com/html-pages/variator-roller-weights-chart.htm#GILERA
    RUNNER 125cc + FX = 19x17
    RUNNER 180cc + FXR = 20x17
  14. italjohn
    italjohn Member
    Thanks for the tip.
    I will check it out later.
  15. MiNoR cOnFuSiOn
    probably find the clutch was changed wiht the variator.. check the bell is true aswell
    the rollers can be used in ether variator, you simply move a lil spacing washer from front to back to accomidate the change in diameter.
  16. italjohn
    italjohn Member
    Ok there is a tiny spacer in the front.
    Is it this you mean?(the black rusty one)
    Inside
    Runner variator
    Typhoon variator
  17. MiNoR cOnFuSiOn
    the order from the front for smaller rollers goes, nut, small washer, starter dog, big washer, outer pulley, TWO washers (thick and thin one) variator on the shaft, pump drive gear.
    for the bigger rollers the thinner of the 2 thick washers behind the outer pulley goes between the variator shaft and pump drive gear. usually missing tho so ill try find the washerr dimentions when i get home
  18. italjohn
    italjohn Member
    No thin washer here, only one "thick" one.
    But should't the two variators have different diameters?
    Mine are bouth the same dimension.
  19. MiNoR cOnFuSiOn
    nope.. same diameter with diff ramps and spaced for whatever size rollers your using. main advantage to the 180 variator is weight.. ive found up to a 20g weight reduction on the 180 variator. can be drilled put on a laith then babanced but this only gives better throttle responce, the 180 ramps as i said are slightly diff an the 180 roller's will last a bit longer. deffo need the washers tho or your front pulley will sit too far back meaning the belt will crab (run out of true front to back resulting in a hell of alot of friction)
  20. italjohn
    italjohn Member
    I have got it out.
    I just put screw inside and pull it, voilà out it come :)
