HELP! Aircool zip problem!
Discussion in 'General Scooter Discussion' started by Phillcl, Nov 10, 2012.
  1. Elliot Bramley
    Elliot Bramley Member
    what rollers are init??
  2. Phillcl
    Phillcl Member
    I'm not sure, they are pretty old, ive got some polini 4.5g rollers coming along with the air filter foam and a new cdi in about half an hour.
  3. Elliot Bramley
    ok u bought a derestricted a cdi??
  4. Phillcl
    Phillcl Member
    Yeah ofc
  5. Elliot Bramley
    i really need some rollers but got no money haha
  6. A-LY
    A-LY Active Member
    get that fookin foam in the filter! it'll be running so lean it puts bob marley to shame.
    my aerox did a kinda similar thing when i had a jet 15 sizes too big init
  7. astro77
    astro77 Active Member
    haha fookin class
  8. Phillcl
    Phillcl Member
    right ive got the new rollers and foam in, still same
    when giving it throttle i cas see the clutch spinning inside the clutch bell but the clutch bell does not move
  9. astro77
    bike will pull off with rollers even if to heavy or to light, sounds like clutch not engaging, was the bike running ok when you got it
  10. Phillcl
    Phillcl Member
    It was a none starter, its actually a zip SP but the watercooled engine was ruined so I put a spare zip aircooled engine i had in the bike, this is the first time ive had it all up and running properly, the only problem is the clutch. I do actually have another clutch but the pads on it look even more worn than the other one. What should I do?
  11. astro77
    take the springs out of the worn clutch and put them in the one you have on at the moment
  12. Phillcl
    Phillcl Member
    There both pretty worn if im honest should I just replace the clutches?
    Only problem is, I lost my 36m socket last night! :(
  13. astro77
    If there really bad the yeah I would, you can get a standard cluch for about 20 quid
  14. Phillcl
    Phillcl Member
    Only problem is I literally have no money, I'm gunna have to make one of these clutches work until I get some money.
    The shit thing is, my mates selling his brand new not even used mallossi clutch for 30 quid...
  15. astro77
    it could be a combination of stiffer clutch springs and worn shoes, I'd try the other springs first or just swap the whole thing if there as bad a each other, you got nothing to loose, well maybe another socket:D
  16. Phillcl
    Phillcl Member
    Ill swap the whole clutch for the other one and hopefully that works, if not I'll have to find 30 quid and get this malossi clutch of my mate.
  17. murerg
    murerg MBK Hero!!!
    Hey,
    First thing first. Get a piece of foam in your air filter. Otherwise you only have an empty box stuck on your carb. Pointless. The whole point of the filter is stop all the shit going through.
    You say it revs funny?... What do you mean by that? Revs high?
    Is the ped all stock except the exhasut (Jetted and rollers set for it already or not?)
    Why did you strip the engine for?
  18. Phillcl
    Phillcl Member
    I've got foam in now, sorted the revs out, thing that was because of the air filter.
    Ped is stock apart from exhausted, has been upjetted for the exhaust and rollers.
    Stripped the engine due to the fact loads of parts needed replacing, crank carb etc...
  19. Phillcl
    Phillcl Member
    It's now 5:19am, finally got the bike sorted, found out the problem was the exhaust, for some reason it ran fine without the leo vince so I'm guessing thats fucked, just bought a standard zip exhaust for 20 quid which ill get mounted in the morning just to last me until payday then I can get a racing exhaust. But bikes finally on the road I guess! I fucking hate that bike right now, its as if its been mocking me, but ill always love it. Goodnight all.
  20. Callum Coles
    Callum Coles 2003 Piaggio Zip Sp
    2003 Piaggio zip sp
    probably the pipe isnt derestricted so that the engine is not producing enough power to engage the probably stiff clutch springs
