Pic 00 The Stage6 subframe allows you to mount your carburetor directly above the rear wheel. Pic 01 Original carburetor location Pic 02 New carburetor position Pic 03 New carburetor will not fit because the braket for the engine mount are in the way Pic 04 I remove the original engine mpount Pic 05 Then it's time for the new two pieced braket Pic 06 Then I mount the subframe Pic 07 Now there's room for the new carburetor! Pic 08 Remove the original bracket from the frame Pic 09 Then installing the new mount on the frame Pic 10 New Stage6 - Membran (VForce3) Pic 11 New Stage6 - R/T Intake+Spacer (FKM Viton®) Pic 12 Nya förgasaren Stage6 - (R/T Flat-Slide) VHST 28 Pic 13 All stuff installed! Pic 14 Before! Pic 15 After! Not translated!
