Gilrea runner help please
Discussion in 'The Workshop' started by Sam phantom, Dec 5, 2017.
  1. Sam phantom
    Sam phantom Active Member
    I’m in the middle of restoring a (y)registered Gilera Runner sp50cc for some one and wanted to ask if any one knows if you can pre mix the oil and petrol ok or weather the oil pump feeds the crank bearings! as well as the oil line that gos to the carb like on the Suzuki’s? Or it just feeds to the carb like on the Minarelli engines
    Thank you.....
  2. Sam phantom
    On further inspection I can only see one line and one line out of the pump but any one that knows the gileras well...I’d be grateful ?
  3. MARSH
    You could pre-mix but the std system work's perfect, it lubes the bearings / piston no problem.
  4. Sam phantom
    Thanks! It doesn't have a separate feed for the crank or any thing like that?
    I appreciate they work well but it’s the age of the bike/pump which is the concern
  5. MARSH
    Fit a new pump, the mist of oil entering the engine lubricates everything !
  6. Sam phantom
    The oil and fuel Both enter the carb before its misted in to the engine so it’s no difrent in that respect if you premix or not!...what I need to know is if there Is a separate oil feed for the crank/bearing
    If any one knows that would be great thanks....
  7. MARSH
    No separate feed to crank/bearings.
  8. Sam phantom
    Thank you for the help
