Gilly runner vxr180 4 toke
Discussion in 'Maxiscooter Tuning' started by bertie, Dec 9, 2008.
  1. MiNoR cOnFuSiOn
    whats all this about not being ablke to change crank bearings? :confused:
  2. monty9120
    monty9120 Active Member
    Vespa gts300
    Well if it is possible its a bastard. the bearings are in the actual casing so changing is nie on impossible or costly when a new engine is cheap enough
  3. bertie
    bertie Active Member
    '93 Skipper LX125
    I guess I could just let a decent garage do the bottom end for me if its very hard on 4 strokes, and yeah your right the 180 will probably last longer than I need, but I could swap engines with a 200 anyway just so I can muck about with the 180
  4. MiNoR cOnFuSiOn
    have you read the manual?
    of course you can change them.. there not cast in place. infact there easier than a 4t as there not heat seated
  5. kyle1b1
    gonna say what kind of engine would that be ?
    be like having a kettle and not been able to re-fiull the water when you used it :rofl:
  6. monty9120
    Vespa gts300
    I remember the bearings are actually like shells or something
