Gilera Runner - Wiring Loom 50 to 125
Discussion in 'The Workshop' started by Grant McGuire, Nov 22, 2019.
  1. Grant McGuire
    Grant McGuire New Member
    Hi, I’m wondering if a Gilera runner sp50 wiring loom will work if I put it on a runner sp125 ? I am buying a gilera 125 from a friend and he says that the electrics don’t work but he has a spare 50cc wiring loom that I can have with it, he said the only thing I would need to do is change is the cdi and it will work the same. Is this correct ?
  2. Mark Emerson Trentham
    Get yourself the wiring diagrams for both & compare them.;).
    Grant McGuire likes this.
  3. Grant McGuire
    Thanks. I will check it out
  4. Stevep
    cdi is different, reg/rec is different from the 50 to the 125
  5. Grant McGuire
    So I could use the wiring loom from the 50 ? But put the 125 cdi and 125 reg/rec ?
  6. 125TypHXR
    125TypHXR Member
  7. Stevep
    No, the connections are different. You'd have to rewire the lot.
    And the ignition curve is different in the 125 CDI.
    Best to look for a 125 loom, preferably complete with all the bits because buying them individually can be expensive.
  8. Grant McGuire
    Okay. Thank you, I will try and repair the wiring that is on there now. If I don’t have any luck I will find a different 125 loom. Thanks for the help
