gilera runner sp50 not pulling off
Discussion in 'Newbie Scooter Tuning' started by chonk1966, Jan 21, 2014.
  1. turbovetto
    turbovetto Well-Known Member
    tweaked ovetto
    I'm sorry Gaz but the above is all the ideas I can think of. And if it is the clutch springs - I want them ! No Joke ! Name your price.
    chonk1966 likes this.
  2. turbovetto
    tweaked ovetto
    It's just occurred to me that you could have the engine running - bike on the center stand - transmission cover off - and then rev the engine & apply the brake. Then you could actually see what is slipping -
    Just a thought.
  3. turbovetto
    tweaked ovetto
    like this -
  4. chonk1966
    chonk1966 Member
    gilera runner sp50
    so do we take the transmission cover off once the bike is running? and you can feckin have em if you want em:D
    turbovetto likes this.
  5. turbovetto
    tweaked ovetto
    Only if you don't have an electric start & need the kick to start it.
    Apply brakes & accelerator at the same time & see if the variator 'bites' & moves the belt up - and see if the clutch refuses to bite on the bell & lay the power down - or vice versa.
    Let us know ! Video ?
  6. chonk1966
    chonk1966 Member
    gilera runner sp50
    I will do that tomorrow and video the results and post them tomorrow evening after I have ridden the bike back here :D
  7. turbovetto
    tweaked ovetto
    Go easy !
  8. chonk1966
    chonk1966 Member
    gilera runner sp50
    I'm 47 that's the only way I know now
  9. chonk1966
    chonk1966 Member
    gilera runner sp50
    hi me again, right we think we have found the problem we messed about with scooter today had the cover off when the bike was running and on the stand, the transmission all worked but when we put weight on it it just didn't want to know, So we checked the compression as we thought there might not be enough power and we are only getting 90 now. Is this enough compression?
  10. turbovetto
    tweaked ovetto
    Hi Gaz
    when you got it - did you rebuild the pston/cylinder ?
    I always have it all off to see what's going on. The other reason I do this is because everyone thinks that paper gaskets/ rubber 'O rings etc are sufficient on their own. This is not true. I always use red CAFF sealant - on the head gasket (or even without a gasket - as I just did on the Piaggio Typhoon) - on the bottom cylinder gasket(s), on the admission stack/pipe etc etc.
    It's possible that the lack of compression could be because the head is leaking - of that the rings are tired -
    Have it off & use some sealant ! A do a ring gap test -
    I don't bother measuring compression - only rings and squitch. And If in doubt - replace the rings.
  11. chonk1966
    chonk1966 Member
    gilera runner sp50
    right'o I will do that. Can you tell me if 90 compression would cause the problems we are having. When I put the cylinder back on I used hylomar blue on the all the gaskets and on the crank case so maybe the rings are a bit tired. I used the torque settings in the haynes manuel and checked the head bolts today all good
  12. turbovetto
    tweaked ovetto
    I honestly don't know. Never done a compression test. Mark E T would know. But it seems very odd that it would scream & not go like that. Even with tired rings. My money is on the transmission. Is there grease on the belt or something ?
  13. chonk1966
    chonk1966 Member
    gilera runner sp50
    Hi. It runs brilliant whilst on the stand but as soon as we take it off the stand and try it with load on the back wheel the engine doesn't give the power it should. The belt is virtually brand new and we have even tried swapping it with a known good belt.
  14. turbovetto
    tweaked ovetto
    Most bizarre. Can you post a pic of the tranny ? Together and apart would be ideal.
  15. Stevep
    I had this exact same problem on the exact same scooter. Changed feckin everything; piston and barrel, all new gaskets, exhaust on, exhaust off, different carb, bigger jets, smaller jets, fuel vacuum, the bleedin' lot.............and still didn't find out what it was.
    The only thing i didn't try was a slightly smaller length of belt.
    This isn't a blue 03 plate scoot is it?
  16. Merlin
    Merlin Old School Biker
    2007 TKR WRC 50
    Worn crankcase seals? Just a thought.
  17. chonk1966
    chonk1966 Member
    gilera runner sp50
    Hi did you ever find out what the problem was? Our scooter is an 04 plate. I have ordered new piston and rings today so we will try that when it arrives I will keep you all posted how we get on Cheers Gaz
  18. chonk1966
    chonk1966 Member
    gilera runner sp50
    Hi and thanks for your input. We fitted new waterpump new main bearings and new seals all from AJ.Sutton. So we are now changing the piston and rings. Cheers Gaz
  19. chonk1966
    chonk1966 Member
    gilera runner sp50
    Hi not going to the scooter now until the new piston and rings arrive. As you can imagine this is so frustrating and thank you again for all your help. I will let you know what happens when we fit the new piston and rings. Cheers Gaz
  20. turbovetto
    tweaked ovetto
    Have a go at the ports with a Dremel if you can. I'm going to post something about this because it really is a major issue - and it takes five minutes. And have a go on the skirt with some emery paper and round it off - especially on the sides of the skirt under the connecting pin holes - (which are like bacon slicers - and stop the oil getting up between the piston & the cylinder wall. Again - takes five minutes.
    What kit did you go for ?
