I have a Gilera Runner with this setup: Dr evo 70 Stage 6 Pro Replica Malossi multivar Malossi fly clutch Stage 6 vforce3 Dellortto phva 17.5 Top performance seals and bearings Rms crankshaft (same as original but maybe a little stronger) I want to put on a different kit because is too slow . Which one is of these cylindera is the best for this setup and I will get a dellortto 19mm Stage 6 sport pro Motoforce racing 70 Airsal T6 Are there any better cylinders for this price? Will it be ok with this crank ( i have done around 8k km with it)
Why not do a gearup kit instead, a different kit isnt going to get you more higher speed really, a gear up kit will though. You could look into getting your flywheel lightened.
I heard that i will have bad acceleration with a gearup kit and this cylinder. I wanted to get a better cylibder and malossi 14/39 gears
