Scooter Shack Scooter Forum
ForumsThe Tuning CenterScooter Tuning
gilera runner 70
Discussion in Scooter Tuning started by hbyart, 13 Jun 2011
hbyart#1
hi, my gilera runner 70 with a doppler 70's kit, open air filter and pm59 exhaust is running on a 99 jet, however it is bogging. does anyone no what size jet i should change this to or could this be down to something else.
since i purchased it i have fitted a primary gear kit, since then it is bogging.
Thanks
tErr0#2
With a standard carb? That jet size sounds huge.
Read and follow both our carb and roller guides. It could be a mixture of both as rollers also give the feeling of bogging.
http://www.scootershack.co.uk/carbguide.html
http://www.scootershack.co.uk/rollerguide.html
hbyart#3
i have found out the stuff......for this setup.....i got a polini hi speed variator, 70's kit, 21mm carb, mini pm59 exhaust and a polini primary gear kit...it has a 97 jet in it at the moment.
tErr0#4
That's still huge. I have a feeling your rollers are way off and it's causing the bogging so you are misinterpreting it as jetting.
hbyart#5
its got mixed rollers of 5.5 and 6.5
making the exhaust port on a 50 wider6 replies27 Jun 2011
honda vision 19874 replies27 Jun 2011
crank replacement for 70CC?12 replies26 Jun 2011
sr 70 R carb choice9 replies26 Jun 2011
08 Speedy2 AC 70cc dellorto 21mm carb problem5 replies26 Jun 2011
New Shape Gilera Runner SP50 Engine Conversion?1 replies24 Jun 2011
Aerox Problem0 replies23 Jun 2011
best carb set up5 replies22 Jun 2011
aerox malossi 70 jet help3 replies20 Jun 2011
Fried piston and rings help please!!!44 replies16 Jun 2011
