Have a gilera 172 malossi 25mm delly carb open filter 102 jet, pm vario 12. Rollers, polini belt, malossi green clutch springs, standard contra, malossi cdi, pm59 malossi reedblock, gearbox is 125 gbox with gkit as does 7.3 turns off clutch to one turn of wheel, What sort of speeds should i be reaching and is there anything wrong or Anything need tweeking with setup? Shows 85 on clocks expected 90+, Previous owner said its the 180 engine but unsure as gbox isnt 8 turns of clutch to one of wheel.... Any info on adding extras or help on setup? Thanks
if it has a gear up kit it should be geared higher then a 180 anyway? as fior speeds my last se up was pm 172 green springs mallossi belt 25 carb tdr pipe 108 jet 125 gearing carbon reeds it would read off the speedo but atucal speed was 78
