I've had my front tire resealed at a garage and they said that should fix it but it's still losing 10-15 psi a day, what else could be causing this? I can still use my moped but it's annoying having to pump up the tire every morning.
Front tire still losing pressure
Slow puncture
Multiple puncture spots on the tire
split/leaking valve
Tire not correctly seated onto bead
Take your pick mate, get it back to the garage get it checked in a water bath for leaks, no leaks, then get them to reseat the tire onto the rim...... failing that replace the tire
split/leaking valve
take it back. They've obviously not done what you've paid for.
Before you make yourself look a twat, drop some soapy water around the valve and the edges of the rim. It'll bubble up from where its leaking. Mark the spot if its the rim with a wax crayon and take it back.
They can clean the inside of the rim with a wire brush and/or scraper, give it a quick brush with sealant and reassemble. i had a similar problem with a car tyre but the sealer sorted it. Its lost 2psi in 6 months since.
If the tyres going down due to excessive rust at the edges of the rim, get them to fit a toob or look for a good second hand wheel
I did the CBT the other day and the instructor said something about if I have been riding on a flat tire the bead would be damaged, would I need a new wheel?
I have had a new tire fitted so that's not the problem
New tires can still have punctures from storage etc.. rare but does happenI have had a new tire fitted so that's not the problem
More threads in The Workshop
| gilera 125 sp oil pump | 24 Sep 2012 |
| Mtkt Speedfight Headlight surround problem | 23 Sep 2012 |
| Honda sky SGX 50 - mechanic needed | 23 Sep 2012 |
| few questions about my zip | 23 Sep 2012 |
| gilera dna overheating | 21 Sep 2012 |
| R reg 1997 typhoon 125 crankshaft help? | 21 Sep 2012 |
| jog r speedo | 21 Sep 2012 |
| Lets get pistachios NRG going :) | 20 Sep 2012 |
| Where to buy petrol & coolant pipes/hose ??? | 20 Sep 2012 |
| Aerox clutch nut problem | 18 Sep 2012 |
